Thread: Panasonic H11 Error Code
Threaded View
10-01-2021, 10:44 AM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Panasonic H11 Error Code
That sometimes depend on when you are making measurments, before or after error indication.
Also it should be masured at DC voltage scale since AC is only carrier.
At what multimeter position did you make your measurments?
Disconect unit from power supply, and wait 10 min. Then connect your measuring instrument and recconect unit and check voltage at first 10-20 seconds.
https://youtu.be/JPgoXH2h-9k
Turn on captions!
You can also make this simple communication tester!
https://youtu.be/hlgbFkL6TOgLast edited by nike123; 10-01-2021 at 11:05 AM.
