09-10-2017, 01:02 PM #1
Principles Of Refrigeration - R Dossat - Solutions to the problems?
Hi, im currently working through Principles Of Refrigeration - R Dossat - SI Version. Does anyone know where I can find the solutions to the problems set out in the book please?
Many Thanks
Craig
09-10-2017, 02:59 PM #2
Re: Principles Of Refrigeration - R Dossat - Solutions to the problems?
The older versions had the solution directly after the example.
09-10-2017, 04:53 PM #3
I have the second edition and at the end of each chapter is a series of problems but no solutions?
10-10-2017, 10:34 AM #4
I have a copy of Wiley International Edition 1961 (IP- version) and after each chapter there are examples i.e. problems/questions together with answers ...
Best regards, Josip
10-10-2017, 02:02 PM #5
I think the 'solution' is to absorb the knowledge of the relative section to understand the answer/result.
10-10-2017, 04:22 PM #6
Go to the back of the book there is an Answer key from page 443.
Rob
10-10-2017, 05:46 PM #7
You make it to easy Rob, if they can't read the instructions what hope is there?
10-10-2017, 06:37 PM #8
11-10-2017, 11:58 AM #9
Thanks for your replies, but I have been through the book and I cant see the solutions anywhere! No answer key from page 443, no answers after the problems as there are in some editions. Mine is the second edition - SI version though.
I have tried to my best to read and absorb the knowledge as suggested but I just wanted to check I had understood it correctly.
Many Thanks
Craig
