Results 1 to 16 of 16
Thread: Auto Air Con
05-07-2015, 05:40 PM #1
Auto Air Con
Is this the right area for auto air conditioning? Does anyone know anything about it?
Just bought a Jaguar X Type and the air con doesn't work. The compressor physically runs but is not pumping as the pressures aren't changing. It had no gas in system on arrival so I've charged it to the correct amount and no luck. Was hoping for a quick fix but looks like a new comp will be needed at the moment
Martin
05-07-2015, 07:30 PM #2
Re: Auto Air Con
First thing to do is pressure check these they are prone to condensors and pipes rotting out on inner wings .......how old is it some of newer ones run cluthless comps thus they always spin the front hub let me no age will check me books if it's clutchless u gas it without resetting ecu it won't pump
05-07-2015, 07:47 PM #3
Hi it's 2006
Martin
05-07-2015, 09:51 PM #4
Re: Auto Air Con
Charlie you continue to amaze, Martin How many hours you working to buy Jags?
06-07-2015, 03:05 PM #5
Is it clutch less Charlie?
And too many hours Grizzly, thought I'd treat myself as the rest of my life has gone to **** lolMartin
06-07-2015, 07:14 PM #6
Re: Auto Air Con
How old is she? I can check I can also check if on Tev or orifice I've had several where people have removed orifice because they assume it's just a filter then u get same pressures just tell me the age please
06-07-2015, 07:22 PM #7
It's 2006 model
Martin
07-07-2015, 06:00 PM #8
I can see this taking a while 😳
Martin
07-07-2015, 07:38 PM #9
Re: Auto Air Con
I will check tomos
09-07-2015, 10:21 AM #10
Any luck on this?
Martin
10-07-2015, 08:17 AM #11
I really need to know if I'm buying a compressor or accumulator kit
Martin
10-07-2015, 05:30 PM #12
Ok so now the condenser is getting cold!? Whilst warm air is blowing out in cabin and yes it's set to cold. No pressure difference either side
Martin
10-07-2015, 10:54 PM #13
Re: Auto Air Con
Sorry for delay just got in anyway it's a clutch assemble like a standard comp so if energised and running and no temp diff at all pull of pipes and spin by hand if no noise from pump pump is shot pencil me ur email and I will give u a number of good cheap supplier
11-07-2015, 06:15 AM #14
Ok thanks will do
Martin
13-08-2015, 07:54 PM #15
Re: Auto Air Con
Does compressor pump when you Rev it?
They are of the spiral variety internally and when run low on gas for a while it wears the seal them only works when you Rev it
14-08-2015, 06:56 AM #16
Re: Auto Air Con
no nothing happens at all
Martin
