Thread: cabinet door seals
25-04-2015, 01:52 AM #1
cabinet door seals
Hi just changed some seals on a double door commercial cabinet had to have them tailor made as this thing had no id numbers,they are the magnetic type the problem I have one door is fine it holds shut the other appears to be weak? any pointers to what may be the problem the doors are approx one metre x point three.
25-04-2015, 08:11 AM #2
Re: cabinet door seals
Is the door frame parallel to the cabinet? this can cause the problem.
25-04-2015, 01:05 PM #3
have you tried heating them up with a hairdryer and pulling them out to stretch themout
25-04-2015, 03:05 PM #4
Seem to remember reading that it can take a while for the magnets to work in door seals, maybe the old one was the opposite way round with regard to the north and south poles, I had one do the same and not really hold the door shut, think we propped it shut with a 20L oil drum overnight and i never heard back so assume all was ok the next day.
25-04-2015, 05:52 PM #5
are the doors spring loaded, maybe increase tension to help compress the seal
foster always send out door gaskets folded up so theyre crap when u fit em
25-04-2015, 11:44 PM #6
They can take time to bed in, i tell customers up to a week and they must firmly push doors closed, magnets seem to be weaker on replacements
26-04-2015, 09:15 AM #7
27-04-2015, 04:44 PM #8
27-04-2015, 07:43 PM #9
Mike u still talking about door seals or is my personal life back on the net again?
27-04-2015, 08:59 PM #10
28-04-2015, 09:41 AM #11
