Thread: cascade system
15-11-2014, 03:50 PM #1
cascade system
hello
aim now try to build cascade cycle to reach -70 c
the high stage work on R404a ,using tecumseh compressor 1/2 HP
the low stage work on R23 ,using tecumseh compressor 1/4 HP
i used capillary tube for both stages
but my problem is in the heat exchanger , i don't know how to select the heat exchanger ,
the calculation show that the heat exchanger capacity is 900 w and to reach -70 , i soppuse to use tube in tube heat exchanger ( 6 m long , diameter for inner tube is 3 mm and the diameter of the outlet tube 6 mm ) is that OK ? or there is a problem in ,y calculations ?
16-11-2014, 02:40 PM #2
- Sep 2009
- Iran
- 66
- 674
- 1
- 19
Re: cascade system
could you draw you system.
and I think it is more safe you use plate heat exchange .
