Thread: Expansion valve matching
16-02-2014, 12:41 PM #1
I have a 230kW evaporator (2x115kW). Would it be better to fit a TE12 with a No.7 orifice or a TE20 with a No.8? System running on 407C
Thanks for your help.
16-02-2014, 12:44 PM #2
Re: Expansion valve matching
Correction;
would it be better to fit (2x) TE12 No.7 (94.3kW each) or (2x) TE20 No.8 (118kW each)
16-02-2014, 12:51 PM #3
I'd go with the TE20s personally. You can always wind the valves in a bit if necessary.
