Results 1 to 12 of 12
Thread: UK Tender
20-09-2013, 07:59 PM #1
UK Tender
this breezed past my eyeline for a tender:
The replacement air conditioning equipment must carry as a minimum a 7
year manufacturer's extended warranty, which the successful supplier will
need to provide proof of with their tender submission.
20-09-2013, 08:11 PM #2
Re: UK Tender
replacement equipment!!- whats the maximum warranty period??
was that in the small print?
20-09-2013, 08:15 PM #3
20-09-2013, 08:21 PM #4
Re: UK Tender
http://nottinghamairconditioning.blo...-warranty.html
tosh- 7 yr warranty
20-09-2013, 08:25 PM #5
Re: UK Tender
Looks like Toshiba it is then http://www.acr-news.com/news/news.as...warranty+in+UK
Marc
20-09-2013, 08:30 PM #6
Re: UK Tender
20-09-2013, 08:49 PM #7
20-09-2013, 08:49 PM #8
Re: UK Tender
Warranty dependent on following recommended service intervals.
Recommended service interval: every two weeks.Mostly found in Oxfordshire, UK :)
20-09-2013, 08:52 PM #9
Re: UK Tender
that's interesting I must contact AMP as I am hoping to put in a rather large order for some SMRHi
20-09-2013, 09:48 PM #10
Re: UK Tender
Its tricky cause any problem with electric supply can and will cause problems, gas leak can accrue after a few years and I'm sure it will all come from installer pocket.
21-09-2013, 07:20 PM #11
Re: UK Tender
It should lead to a customer for life, warranty with installer etc.
Colleges here are insisting on 5 year minimum, but include for 2 visits per unit per year, cost agreed per year, so tends to favour larger companies.Mostly found in the southern part of this green and pleasant land.
13-10-2013, 09:37 PM #12
Re: UK Tender
If the installing Company is A Mitsubishi Business Solution Partner, then those installers are able to offer a 7 year warranty on Mitsubishi equipment. Just have to find an installer to carryout this installation with this accreditation, and Mitsubishi Electric kit will have the required warranty period. And if its replacement tech, then this could be your brand.
