Results 1 to 1 of 1
Thread: FES Screw failing
17-02-2013, 10:23 PM #1
FES Screw failing
Greetings,
I have an FES screw compressor package with the old Micro II controls. The thing fails out on Param Limit 5. Problem is there is no Param Limit 5. I look at the list of limits and the fifth one is Suction 2 pressure upper limit. I don't use the second suction setpoints on that machine at all and, even if I did, I have them set the same as Suction 1.
Anyone run into this issue before?
Iceman717
