Thread: Vehicle A/C Top-Up
04-10-2012, 08:30 PM #1
Vehicle A/C Top-Up
How to recharge you car on the cheap VIEW
04-10-2012, 09:34 PM #2
Re: Vehicle A/C Top-Up
His next trick, how to drive to the ER with a set of missing fingers inexorably part of a welding glove...........
05-10-2012, 11:26 AM #3
I like the way he keeps shaking the can
05-10-2012, 12:44 PM #4
Well done Frank, that was a good find. If only it was that easy.
05-10-2012, 12:48 PM #5
If he only knew that r-134 should be at liquid state before entering the system.
He also answering your questions while you are watching....
05-10-2012, 08:10 PM #6
He also has the thermometer in the cab vent but the selector switch is set for demisting the windscreen.
07-10-2012, 10:43 PM #7
I guess that we are all far too observant!
I refuse to work on cars that the owner admits to self-charging, especially if they have used the leak stopper as well.
The problem is, if they don't bother to tell you and you end up with gummed up gauges etc.Mobile A/C at its best, see avatar.
