Results 401 to 450 of 521
Thread: What did we do today?
09-08-2012, 07:54 AM #401
Re: What did we do today?
Hey Dude,
I really hate that schrader thing, always seems to hit/spray the groin /nut area. The flare nut flies miles away, the gauge hose never connects straight away. Then end up walking around with oil everywhere like you have piss'd yourself, friggen hate that. ( but suniso is very good for the SKIN so to speak, last time I looked. )
31-08-2012, 11:26 PM #402
31-08-2012, 11:34 PM #403
26-09-2012, 04:07 PM #404
Today I am Mister delivery...... Transport strike means I got promoted to delivery boy, just a few little parcels, nothing much............... Fill van to roof, sitting in seat with parcel on lap and still another load to do before knock off O clock. One little load was 111 boxes! Still got half to go fetch and drop, will take van home tonight, even if it is a pain to park, will be less time on my clock, and of course no bleeding overtime........... Sheesh, at least the heater is working in the van, though only in summer, and the fan is knackered and needs to be changed. Van aircon is open window and get hijacked, or close and cook.
01-10-2012, 10:29 PM #405
Replaced A Helical Oil Seperator with a Temprite today. I was dreading repiping but it went in smooth. Now im paranoid because it went in so nicely on a Monday......Somethings gotta give
02-10-2012, 05:50 AM #406
One of the pipes at the back will crack in 3 months..............
04-10-2012, 08:38 AM #407
One of the "Good paying" pubs i work for had a costly renovation 3 years ago in the public bar. Contractor has had never ending trouble including two buggered 3 phase compressors. Glad it wasn't my drama however, today was a different story as that company has apparently gone to the wall and now i find myself diagnosing their THIRD compressor failure.
The writing was on the wall, don't install another compressor because there is obviously an underlying problem... Take some time to do the maths....Find they had mismatched the condensing unit to the cooling capacity of the evaporators.
It pays to do a background check!To the optimist, the glass is half full. To the pessimist, the glass is half empty.
04-10-2012, 05:09 PM #408
How badly were they out?
Still doing the Mister Delivery, now 2 weeks on. Drove yesterday through one of the strike zones, nothing to see, though they have been and beat up the one courier, and one Owner driver lost 2 rigs to the "unfortunate criminal elements not associated with the striking union members" who stone them and burn them.
Now that summer is finally showing up I am starting to get complaints about aircons...... One leaking pipe to fix tomorrow, leaking water drain.
04-10-2012, 07:16 PM #409
Got home early for only the 2nd time this year !
Bounced on the sofa & squashed me left gonad !!!If the World did not Suck, We would all fall off !
04-10-2012, 09:18 PM #410
Next time use the jocks....... and take the jar and place it on the shelf your wife specified will hold them after the words.......
05-10-2012, 09:49 AM #411
All day at the pub. Underneath it to be specific. The owner wants a quick resolve to yesterdays compressor failure. "Stick another compressor in." he says...My thoughts:
Not with that system's history.
2 minutes later, in comes the staff manager and he isn't interested in putting this weekends alcohol on ice.
Shows me a kit that was removed from service when the renovation took place 3 years ago.
3 Phase, Hmmm..R404a yeah, but only 70 ish per cent of current condensing unit rating.
So, as a temporary solution, ( BY REQUEST/DEMAND).. hook it up. Condensing unit is moved close by,...sitting in the dirt., and i used the buggered units HP/LP by tossing the LP line onto the old burn-out suction line drier after the valve was removed, then extend the HP line to fit on the temporary liquid line.
This setup is working finebut customers ain't going to have cold p*ss tonight.
05-10-2012, 04:16 PM #412
Tell em it is British beer nigh, and it will be served warm..................... Have your running shoes on though, and a clear path to the rear exit, along with a couple of crates to pull over and block the exit behind you.
08-10-2012, 10:29 PM #413
laid at home on the gonad crushing sofa feeling sorry for myself
as I have man flu !!!If the World did not Suck, We would all fall off !
09-10-2012, 09:44 AM #414
Paper work, and more paper work. Definitely going to need glasses soon as the writing is going out of focus
Later on... residential reverse cycle swimming pool heater not working?? (28 degrees C outside..!!) : i'll be there in 30 minutes.
Sean B. Sorry.. i haven't answered your question.
The condensing unit installed at this pub,was around 30% over sized.
That company must have calculated the maximum load, but didn't consider the 2 other smaller "Glass chiller" sections to cycle on/ off on solenoid.
The result was: Compressor short cycling on reduced load when temperature is obtained in just one of 3 areas. (No short cycle delay timer,Install Monkey) p
Short cycling = oil loss from compressor, and shortened life of compressor when cycling too many times/ Hour.Last edited by mikeref; 09-10-2012 at 10:40 AM. Reason: More to add.and no new toaster yet.
09-10-2012, 05:15 PM #415
Just do what half the pubs here do and leave a door open always...............
13-10-2012, 04:12 PM #416
ON CALL. Sitting home waiting for the phone to ring. I already drank about 1 gallon of Coffee..ho hum ho hum.
14-10-2012, 10:44 AM #417
It will ring when you are busy paying the penalty for drinking all that coffee, and are in a small room with a bad echo............ Don't drop the phone in the you know what
14-10-2012, 04:26 PM #418
14-10-2012, 06:51 PM #419
Har!
Watching Red Bull Stratos, the pressure outside at 38.850km is nearly lower than what my vacuum pump can deliver................
14-10-2012, 08:10 PM #420
14-10-2012, 09:42 PM #421
2 and a half hours up, less than 5 minutes down................
20-10-2012, 12:41 AM #422
Today (well technically yesterday now but who cares) The Viking handed the van and the tools back...
14 1/2 years with the same logo on my T-shirt has come to an end, on Monday the next adventure starts.
20-10-2012, 06:37 AM #423
20-10-2012, 09:11 AM #424
Good luck with the new job! 14 years with the same van and t shirt no wonder you are leaving
20-10-2012, 12:11 PM #425
T reg van and a t-shirt that stinks? Dont blame you!
20-10-2012, 06:03 PM #426
Relaxed today, first day as unemployed
@Grizzly, neither really I took a sideways step.
Starting on Monday I will be the Project Manager for a small company that import and sell dry coolers and cooling towers.
So if anybody needs a dry cooler or 2...
20-10-2012, 07:44 PM #427
Will you be drawing the Dole for the 2 days you are unemployed??
Good luck with the new venture
20-10-2012, 08:15 PM #428
20-10-2012, 10:35 PM #429
Thanks guys.
21-10-2012, 11:28 AM #430
Got new job on 1st October first week out on my own, doing controls and leak detection, something completely different, no standby, Monday to Friday, all going good so far, would i go back to supermarket fridge???????????
no blocked drains, iced up cases, hum????????
j.j.Remember: 'ITS NOT HOW GOOD YOU ARE ITS HOW BAD YOU WANT IT'
21-10-2012, 07:35 PM #431
2nd day of unemployment, I can feel the apathy setting in. I got my cozy on and a Stella in my hand, perhaps I should start smoking as well?
J.J. So changes are good then?
23-10-2012, 07:21 PM #432
Thought you were self employed Viking?
alMostly found in the southern part of this green and pleasant land.
23-10-2012, 08:38 PM #433
Nah,
Sorry Al but I'm addicted to a paycheque at the end of each month
25-10-2012, 10:41 PM #434
01-11-2012, 05:11 PM #435
Today i started inspection / service to SMC 116.
My thumbs are sore in advance because all of those piston rings
01-11-2012, 08:04 PM #436
Drove 200 miles to give a client handover demonstration, only to be told "Ohh good, I know how to work these, I already have Toshiba in my other shops" agrrrrhhhhh
She's having Hitachi in the next one.......or Chigo.
Eggs
13-11-2012, 12:07 AM #437
Bosses were gone today...I Cleaned out the Parts room. Thew out so much garbage...well, Garbage is the term that I use to describe parts that we will never use. Some of the stuff I found was just plain funny....Anyone in need of a 135 Ton R-22 TXV, let me know I have 5 of them
13-11-2012, 12:18 AM #438
drove 490mile round trip to deliver a 6 ton container to excel in London, to find out we should have been there for 8am!,escorted the 33 ton wagon , had to get display stands dismantled, got into position for siting on the 8x3 floorspace, and as its on the 1st floor,waited over an hour to see if 38 ton on 4 outriggers with the weight displaced to the majority over 2 outriggers complete with foot pads of 18 inch sq is less than 18knewton????- finally go the go ahead,and all ok, although the outer outrigger did lift 2 inch so there must have been some deflection in the concrete floor slab!, left at 5pm home for 9 30 as 18mile queue on the m1
13-11-2012, 12:57 AM #439
13-11-2012, 08:05 PM #440
Deflection is not a bad thing, but when you hear creaking that suddenly stops NOW is a good time to be far away, or at least not on the floors below.
13-11-2012, 09:39 PM #441
I did fook all today and got paid for it, so today was a good day, At least I didn't have to baby sit a posh shipping container like the monkey.
I did however condemn a load of Kaysun splits only 11 months old and every one leaking on flares.
24-12-2012, 03:36 PM #442
Craned a couple of VRF Toshiba condensers onto the roof ready for next nearDSC05224.jpgDSC05225.jpgDSC05227.jpg
24-12-2012, 05:26 PM #443
24-12-2012, 09:39 PM #444
Last minute jobs. Back packers kitchen fridge. Condenser fan motor (that runs in reverse for 30 seconds when compressor cuts out) went leg up. Nope. No spare in my ute and couriers shut down for Xmas.
Stick in conventional motor and bypass reverse module. Sorted.
( Had to have been people from 4 or 5 non english speaking countries in the kitchen during that time... Could only talk to the fridge)To the optimist, the glass is half full. To the pessimist, the glass is half empty.
25-12-2012, 09:53 AM #445
At least the fridge replied by blowing it's fan at you.
02-01-2013, 12:17 AM #446
Customer complains his newly installed window shaker doesn't cool.
Switch it on and it seems fine for the first few minutes then compressor cuts out. (you'll never guess the answer.)
Before sliding it out i went outside to see if he had placed a "Box" cover over it,(as i've seen done before) but to my surprise, the air vents on both sides were blocked off!!
No air flow through condenser. Why did you block them off? To keep the bugs out.To the optimist, the glass is half full. To the pessimist, the glass is half empty.
02-01-2013, 12:41 PM #447
02-01-2013, 07:33 PM #448
Ordered a grands worth of driers and oil for an imported milk cooler with moisture issues!
http://www.youtube.com/watch?v=AH6-b...cissrQ&index=2Mostly found in Oxfordshire, UK :)
03-01-2013, 07:24 AM #449
You will need more driers........... have fun.
26-01-2013, 12:05 AM #450
Today?
25°C at lunchtime, BBQ going, outdoor A/C running...
What did you do today?
By TimSaxon in forum TransportReplies: 22Last Post: 26-11-2010, 08:40 PM -
38 today
By bernard in forum Chit Chat & Service StoriesReplies: 7Last Post: 24-06-2007, 09:14 AM -
don't put off until tomorrow, do it today!
By eggs in forum Chit Chat & Service StoriesReplies: 2Last Post: 20-10-2004, 09:06 PM -
Iraq today, but who was innocent yesterday
By shogun7 in forum Chit Chat & Service StoriesReplies: 10Last Post: 18-10-2004, 09:58 PM
