    May 2010
    Presently in Tanzania
    63
    1
    Thumb Rule for Refrigeration
    What is the relation between Compressor Capacity in TR and Cooling Surface of Condenser? What is the relation between Compressor Capacity in TR and Cooling Surface of Chiller?
    Compressor TR and HP of the drive motor?
    May 2012
    1,528
    Re: Thumb Rule for Refrigeration
    I'm not sure what TR is?????
    But in the UK we have a rule of thumb that....
    The evap temp is 10degs lower than the air off
    and
    The cond temp is 15degs higher than the ambient.
    Not set in stone and will vary dependent on products and
    Delta T's but a good one to get you going...
    Rob
    Mar 2008
    232
    Tons of Refrigeration (12,000 BTU/Hr)
    Location, United Kingdom
    May 2012
    1,528
    Quote Originally Posted by B G Scott View Post
    Ah Tons of Refrigerant eh?
    Just testing
    Rob
    Oct 2003
    5,630
    There not a relation and surely not as arule of thumb
    Nov 2008
    india, delhi
    14
    this is not related to TR.
    1 TR=12000 Btu/hr
