Results 1 to 10 of 10
    May 2008
    Newcastle under Lyme
    112
    Mitsubishi City Multi PURY-P300 Condenser Coil
    Hi people,
    Just on the off chance that anybody on here has done it before...
    I am in the process of removing a condenser coil (heat exchanger in Mitsi language) on a Mitsubishi 'City Multi' on R410a.
    Its obviously quite a new unit but the copper passes have split at the bottom of the coil caused by either liquid hammer or vibration.
    Where do you start? Is it a case of just slowly removing access panels or is there a certain process in which panels to remove first?
    I have google'd this on the off chance there may be a pdf file from Mitsi in the form of an exploded diagram or some kind of assembly plan.
    I am lucky enough to have been on the two day 'City Multi' course but the two operation manuals and A4 binders we were given don't shed any light on this.
    I know I'm clutching at straws but thought I'd post on here to see if anybody could shed any light on this, before I go back to site.
    feedback greatly appreciated.
    Jun 2009
    Lusk , Dublin
    1,115
    Re: Mitsubishi City Multi PURY-P300 Condenser Coil
    Top off ,fan deck off, front off ,back off ,sides off.
    Well that's how I do it .
    Done a few ,you'll need a side kick to give you a hand.
    You'll get an exploded view in the spare parts manual if you have it.Don't have one to hand.
    Stu
    Nov 2008
    birmingham
    155
    pretty much as stu said, ive only a couple but they come apart pretty easily,
    Kev
    manchester
    5,639
    take ur time, remove all coil.pipe thermistors and dont overheat the end stubbs-good luck- and enjoy ur trip to the scrap yard
    May 2008
    112
    Thankful of the feedback gents, much appreciated!! Scrap yard was a must, but had trackers fitted in vehicles last week + doubt it would fit in car!!! Thanks again
    Mar 2011
    Singapore
    212
    Just take note of advises from Stufus and IM
    May 2008
    112
    Ace photo! Cheers very much for that!
    manchester
    5,639
    trackers- when u park up on site- unplug it and leave it on the floor- it has battery back up for 8 hrs- once youve visited the recycling ctr return to site and carefully plug ur tracker black box into the lil connector- be carefull not to bend the pins- othrwise an £80 tamper fee applies- if its fleet smart-make sure u have black duct tape or coloured cable ties from rs as they like to try and prevent this-ps lead round the gps ariel doesnt work-ive tried!- or plan b check for an app for scrap yard locations-or get the apprentice to carry it
    Quote Originally Posted by Daz man View Post
    3,853
    Had a tracker in the van but i eated it
    http://t1.gstatic.com/images?q=tbn:A...olDlBRmXl0WLQw
    Jun 2009
    Lusk , Dublin
    1,115
    Surely part of the job description is to remove all waste from site for licensed disposal (cash)
    Stu
