    hienbk71's Avatar
    hienbk71 Guest
    pressure loss Flexible ducting calculator
    Hello every body. I'm Hien.
    I'm designing a air conditioning system for hall. I need to a software to calculate pressure loss of flexible duct or a catalogue that have pressure loss of flexible duct, example Pa/m
    E-mail removed
    38
    Re: pressure loss Flexible ducting calculator
    The flexible ducting manufacturers will publish duct losses in per metre rate versus air flow rate.
