Results 1 to 1 of 1
19-09-2011, 06:39 PM #1
carrier split unit model no 38hkc indoor unit given alaram 5time light flash
hi to you all , i have a carrier wall type 1800btu split unit. indoor and outdoor run normally but after 10 min indoor and out door both off then 5 time green light flash i changed the coil termister and temp sensar and check the gas also ok i can not understandany one can help me plz thnx
