Thread: Fujitsu technical info
22-07-2010, 07:01 PM #1
Hi chaps i need some help locating a technical manual for a Fujitsu AJYA90LATF it's a V series unit. We are having trouble with the inverter compressor but not sure if its the inverter comp or the inverter board. Looking for a PDF file for this unit can anyone point me in the right direction.
24-07-2010, 03:22 AM #2
Re: Fujitsu technical info
I've been using Fujitsu general. It's a bit of a gong show finding your way through their site but all the information I have needed was there.
24-07-2010, 08:59 PM #3
i tried that but had no joy, they have a new site called fgeurofred which is just as bad. i managed to speak to someone from there technical dept but they sent me the wrong info...
28-07-2010, 01:59 AM #4
What units are you trying to get info on? I'll try and send you a link.
14-09-2011, 05:48 PM #5
Hi Chaps,
I'm trying to get hold of tech info / schematics for a Fujitsu ARY30EL(B) indoor unit. (cooling only)
I can't find them on any of the Fujitsu sites.
I'd like to slow the blower speeds down a bit as its very noisy. (if that even possible...)
cheers
paul
14-09-2011, 09:51 PM #6
Paul
Might be best to start a new thread, your request will be lost in the replies to the OP.
RBK have you tried wave-ac.co.uk?
FGeurofred are the main UK agents, in general if looking for manuals email them with model and serial number, have you tried using a basic inverter tester to determine if compressor or board is faulty?
Is this a warranty claim? Just curious as i normally replace both especially if i suspect the compressor, this has been recommended to me by various manufacturers tech departments.
alMostly found in the southern part of this green and pleasant land.
Fujitsu Technical Helpdesk
By rootsy in forum Heat PumpsReplies: 2Last Post: 17-02-2010, 06:07 PM -
Compressor Technical info.
By Chunk in forum Technical SpeculationsReplies: 2Last Post: 03-05-2008, 09:27 PM -
Some technical info
By Josip in forum Refrigeration BooksReplies: 5Last Post: 15-01-2008, 09:38 PM -
fujitsu tech info
By Krups in forum Air ConditioningReplies: 11Last Post: 01-12-2005, 07:41 PM
