Thread: Hand oil pumps
    May 2009
    New Zealand
    141
    Hand oil pumps
    I'm looking to get a hand oil pump that can pump good volumes of oil against pressure but all I have seen from the fridgy wholesalers is the likes of the Refco or Yellow Jacket hand pumps that can pump against pressure but can't pump the volumes. We have a good electric pump but it's not always handy.
    What do you folks use?
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Hand oil pumps
    I use on large compressors and oil reservoirs an electric oil pump.
    I can only get the details tomorrow.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Hand oil pumps
    Its called VISCOMAT 70 and you can find all the details here: http://www.flowfitonline.com/acatalo...PUMPS_480.html
    3,853
    Re: Hand oil pumps
    You could suck some oil into a clean recovery cylinder, vac it out then used the system discharge pressure to push it out again.
    I think the pressure you need to be able to pump against with a hand pump limits the volume pet stoke, one with a high volume would need your whole body weight behind it to move any oil, hence the low 50ml per stroke of the refco pump.
    manchester
    5,639
    Re: Hand oil pumps
    shut suction and discharge valves and vac out the compressor body only and then use a normal hand pump and the oil will flow a lot better. also get a boy to pump it instead
    Re: Hand oil pumps
    Shut the compressor valves, vac out the compressor to 0 psi/bar.
    Connect your oil line to the compressor, run vac pump and suck the oil into the compressor.
    May 2009
    New Zealand
    141
    Re: Hand oil pumps
    Thanks for the replys.
    I will check out the possiblity of a small gear pump that could run off a electric drill or the like. Had a look at some of the hydrolic outfits recently with out any luck.
    38
    Re: Hand oil pumps
    Hi Superfridge.
    My electric pump was supplied by Danfoss Hydraulics in Mt Wellington The size of an average vac pump.
