Thread: auto cascade
    Jun 2007
    us
    68
    10
    auto cascade
    I am trying to build a auto cascade freezer. Any help would be greatly appreciated. Trying to reach -60C
    Moscow
    40
    82
    Re: auto cascade
    Use propane on low cascade and CO2 on high one. I heard something about analog. Do you want to use it for CPU cooling?
    Apr 2006
    1,620
    Re: auto cascade
    Vango, you're being a tad vague, with the amount of detail you gave me my best answer I can give is : Yup.
    Thats it. More detail then we can go some where
    Oct 2003
    5,630
    Re: auto cascade
    An autocascade is not the same as a cascade.
    An autocascade uses the principle of a gas mix (2 or more, even 6) where each is separated frm the others and where each extracted gass then cools its own heat exchanger/gas separator to separate the next gas in then 'diluted mixture'
    Oct 2005
    IRAN
    878
    Re: auto cascade
    Hi Vango,
    As Peter said auto cascade is different.
    Please have a look at the attached file which is a simple example of auto cascade system.
    Attached Files Attached Files
    Even Einstein Asked Questions
    Moscow
    40
    82
    Re: auto cascade
    Thank you Peter_1 and Lana. Your observation about autocascade was useful for me. I made a mistake, sorry ;(
    Jun 2007
    us
    68
    10
    Re: auto cascade
    thank you for your reply. I found Iana,s sketch especially helpful.
    Moscow
    40
    82
    Re: auto cascade
    I just find some links about autocascade: http://gomeler.com/2006/07/06/autocascade-design/ , http://forums.extremeoverclocking.com/p2762737.html . This guys made their autocascade machines.
    cascader23's Avatar
    cascader23 Guest
    Re: auto cascade
    Hi there, I am new to the forum and I have a question on the auto cascade. I am in the process of building a auto cascade system and I was trying to use R-507 and R-23. In your opinion can I make these work in a system piped accordind to your layout? Are you using a flat plate heat exchanger for phase change? What ratio of refrigerant have you found to work well. More R-23 than 134a?
    Jun 2007
    Norway
    56
    Re: auto cascade
    Hi cascader 23.
    If you just need -60c, you can go the easy way.
    Use ISCEON MO89 which is similar to the R13B1 wich is gone out of business for many Years ago.
    That one make easy -60c on a standard system.
    Not sold in the US or Canada due to flameable in some conditions.
    Wish you all a Happy New YEAR
    Sep 2005
    Atlanta Georgia USA
    80
    Re: auto cascade
    ASHRAE Refrigeration Manual had a pretty good explanation and diagram of the auto cascade system.
  1. problem in Auto Refrigeration Cascade System
    By ernestlin in forum Trouble Shooting
    Last Post: 01-07-2009, 12:41 PM
  2. Freeze Up Auto Or Manual In Chiller?
    By abbasi in forum Fundamentals
    Last Post: 10-02-2006, 02:48 PM
  3. HP Switches (Manual or Auto)
    By Latte in forum Technical Discussions
    Last Post: 02-06-2005, 07:48 PM
  4. Regulation regarding hydrocarbons in an cascade
    By DaBit in forum Fundamentals
    Last Post: 19-01-2004, 12:42 PM
  5. Auto Cascade
    By dwallan in forum New Technologies
    Last Post: 11-05-2003, 02:00 AM
