Results 1 to 16 of 16
09-07-2010, 05:43 PM #1
Yellow Jacket 18975 1/4" Core/Vacuum Charge Tool
hi guys does anyone have experience with this type of tool, (the 18975 with the gauge port)
http://www.amazon.com/Yellow-Jacket-.../dp/B0014JDNVO
im liking the idea of removing schraeder to vacuum and charge, unsure how much of a difference it will make? anyone else have any opinion?
I have charged using refrigeration back/open/front seated type service valve (king valve on the receiver if my memory serves me correctly?, could well be wrong)but cant remember how fast fast the gas went in?
I suppose I want to know if the £30 od is worth it?
EDIT: just realised its a 1/4" so I couldn't use it on 410a, is it possible to buy a 1/4" male to 5/16" female?
2ND EDIT: found an adapter http://www.ryanairconspares.com/mast...ter-p-760.html incase anyone is interested, obviously not to be used on gauges not designed to take 410a pressures, couldn't be used with valve core tool mindLast edited by SkyWalker; 10-07-2010 at 07:39 PM.
09-07-2010, 10:38 PM #2
Re: Yellow Jacket 18975 1/4" Core/Vacuum Charge Tool
Very useful tool, recently got a new one from Climate Center which included a R410a adapter.
Yes, evacuation speed will increase, you now have a hole the size of the outside of a valve core instead a hole the size of the valve pin.Brian - Newton Abbot, Devon, UK
09-07-2010, 11:25 PM #3
yes skywalker they have been on the market for 30 years they are ideal for changing the scrader valve core , without de- gassing the system.
09-07-2010, 11:29 PM #4
I've got one similar, great little tool for changing schreader cores while system is under pressure. also speeds up recovery vacing etc.
you can get a 5/16 threaded one for 410A also.
10-07-2010, 09:21 AM #5
Get the 5/16 inch one. One thing the note is the 5/16 inch one has a 5/16 vacuum port on it not 1/4 inch. Its ideal to attach a vacuum gauge via a copper pipe to with no vac loss.
10-07-2010, 10:25 AM #6
Sorry guys but how does this work? Are you saying you can
remove the shreader valve to vac and charge? How does this work?
10-07-2010, 11:24 AM #7
Get a version with a ball valve as the shut off valve. My first one was the gate valve type, and when the main seal went, no-one stocked spares! I bought a ball valve type to replace the first one, & never had a problem with it.
Alec, that's what the tool is for. Removing the schrader (sp?) valve to make vac & charge faster.
10-07-2010, 05:18 PM #8
Ye but once you have put a vac on hey system how do you put the shreader back?
10-07-2010, 05:38 PM #9
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
10-07-2010, 07:17 PM #10
That's well good definately ordering one of them!
10-07-2010, 07:31 PM #11
thanks guys, i will also be ordering one! worth the £
10-07-2010, 08:48 PM #12
Never seen or heard of them! But def going to order some. Will make it quicker and easier to vac/reclaim systems
11-07-2010, 08:47 AM #13
No frigie should be without one of these, I have three of them along with all the extras like 3/8 X 6" ballvalve lines for the bigger stuff. Check them out on their web site yellow jacket (ritchie) superheat calculation kit. I now I go on about this product but I think it's one of my best tools and can speed up evacuation by 4 times faster!
16-12-2010, 02:26 AM #14
yes indeed a very efficient tool , reduces vacuum time and replacing schrader valves are a easy job .. recommend
17-12-2010, 10:08 PM #15
javac do one for 1/4 and 5/16 ports but ive broke 2 already-by tightening onto the schraeder port u cannot unscrew it without rotating the entire tool then eventually the threads fail and u have gas rushing thru an open port! not good when the system has glo stick in and the schraeder port faces the main pcb on a 250 panasonic urban-had to jam a core in ,got burnt-lost approx 4kg of gas,and had to dry the oil off the pcb!!!javac say from overtightening!!!
21-12-2010, 07:39 PM #16
Great tool, we sell about 300 of these a year, a tech's must have!
Yellow Jacket 40802 and DRSA 1200
By marc5180 in forum Tools and CalculatorsReplies: 1Last Post: 28-10-2009, 03:27 AM -
Yellow Jacket System Analyser
By Lancelot in forum Tools and CalculatorsReplies: 5Last Post: 18-10-2009, 09:11 AM -
who sells yellow jacket tools in uk
By TRASH101 in forum Tools and CalculatorsReplies: 16Last Post: 22-03-2009, 11:20 PM -
Yellow Jacket
By eggs in forum Tools and CalculatorsReplies: 5Last Post: 14-02-2006, 09:23 AM
