    iceskater's Avatar
    iceskater Guest
    Air flow restrictiorn for Trane Koolman
    Hello,
    Does anyone know what the air flow restrictions are for the propper operation of Trane Koolman mini-chiller? I would like to know if it is correct to place a unit behind another unit or what are the recomendation for a propper installation.
    best regards.
    Re: Air flow restrictiorn for Trane Koolman
    According to the Trane data booklet
    http://www.dalkia.com.au/literature/...N_cgakcgar.pdf
    The maintenance space required around the unit is:-
    Front, air outlet - 1500mm
    Sides - 300mm
    Rear, air inlet - 500mm
    Top - 500mm
    Aug 2001
    Gold Coast, Australia
    600
    28
    Make sure that you stick to the minimum free area as Brian has posted. Then, increase as required if the units are in a well. Look out for situations that could cause discharge air recirculation. And for heaven's sake don't discharge one condenser into the other or have the discharge facing each other without controlling the air path!
    Consult your local Trane office. After all, they're supposed to know all this stuff!
  1. Really weird refrigerant flow issue
    By paul_h in forum Air Conditioning
    Last Post: 13-04-2010, 05:13 PM
  2. flow switch connection
    By afeef in forum The Trail of Tears
    Last Post: 23-12-2009, 06:55 PM
  3. Pulling faster vacuums
    By Aranon in forum Fundamentals
    Last Post: 04-09-2009, 07:32 PM
  4. Flow Rate through Fan Coil Unit
    By deepu in forum Air Conditioning
    Last Post: 21-07-2009, 06:42 AM
  5. Capillary Tube Characteristics
    By Chef in forum Fundamentals
    Last Post: 10-03-2009, 01:03 PM
