Results 1 to 14 of 14
Thread: dryer for vegetables
05-01-2005, 09:50 AM #1
Re: dryer for vegetables
HI
In south of italy they uses such a maschine,the tomatos are cut in 4 parts , i-ve never see the procedure,because i've never been there.Also I now the temperature must be betwin 50*C -65*C. Too keeap the original taste.Even I taste*t 2 piecess ,is like a piece of wood at beghyning, then is very sweat like sugar.The quality of soucess is even beterr than the original fress flouwer.But how the water is throw outside the room? 850 kg/8h.This procedure is also use in medicine,maybe there is using only heating process .Somebody thould me for that we must use a vacuum procedure to trow avay the moisture air + water.
05-01-2005, 03:56 PM #2
Hi Servicefrigo.
Thats the oven I was talking about, the humidity is sucked out with a fan.
I think if dry with vacuum, it will look different and might fall apart, it depend how long you keep it in vacuum. Why not give it a try and put one tomato in a glass jar and vacuume it and see for yourself what comes out.
Chemi
05-01-2005, 04:21 PM #3
Hey there , as for drying food i saw 2 systems , the first duting my study at the university , it was system called lypophilizator , that's deducted to dry liquids and obtain powder , such as milk and orange juice , the system is manufactured by electronicavenetta Italy and is good , it's based on a vaccum of the environement of the milk tank , then cooling it to a very low tempreture , the water evaporates and we obtain a residu of powder milk , i think that this type of systems will work with vegetables also as long as the vegetebals are crushed .
The second system was a solar food dryer that i read about in the home power magazine , but i takes a very long time to dry the food , to check about this solar system go to http://www.homepower.com/files/fooddeh.pdfEngineering, sciences, math, physics and my brain will generate "not responding " soon
05-01-2005, 04:41 PM #4
Hi Botrous.
lypophilizator = freeze dry.
Look a few posts back and you can get the link to see how it works.
Solar vegetable drying is good fun when the sun is up and you only make a small amount.
I think that Sevicefrgo means industrial manufacturing.
Chemi
05-01-2005, 09:27 PM #5
Thanks Chemy , i know that solar drying is for fun and for small quantities , but the freeze dry i thgough that it's different from lypophillisation . thanks for the information
06-01-2005, 08:08 AM #6
I new , vacuum does*t do the job, alone .He must bee complementar with a deep freezing . 1 h ago I whose locking the site you recomanded
http;//home.howstuffworks.com/freeze-drying.htm
thank you ,is a very good site.
11-01-2005, 09:28 AM #7
http://www.heatpumpcentre.org
Click publications
Then Newsletter
Search
Download N1/1999 Ground source heatpumps. There is an interesting article in it "Using a heat pump dryer to dehydrate agricultural products"It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Building a Freeze dryer
By kennedyb4 in forum FundamentalsReplies: 15Last Post: 25-07-2009, 06:24 PM -
UltraTroc Air Dryer Failure
By Robearbam in forum Trouble ShootingReplies: 3Last Post: 19-04-2005, 11:50 AM -
oil pressure problems on air dryer
By edge in forum Trouble ShootingReplies: 1Last Post: 16-07-2002, 02:10 PM
