    3,364
    Pipe insulation breakdown large NH3 plant
    Has anyone out there have information or articles on heat load imposed on refrig plant due to deteriorated lagging .
    Client trying to justify replacement of lagging ( old polystyrene type ) to management .
    System has -40 C & -10 C liquid overfeed system with long piperuns in ceiling & outside ( -40 outside ) .
    System is installed in tropical climate which is my immiediate concern.
    Thanks in advance
    Pennsylvania
    113
    Re: Pipe insulation breakdown large NH3 plant
    I can't offer any advice on calculating the heat load imposed by bad insulation but there may well be a regulatory cost associated with it.
    Take a look at some OSHA citations on the matter at: http://taocompliance.com/news/?p=30
    You may be able to justify it as a cost-avoidance issue.
    Nov 2004
    China
    176
    Try this program to calculate heat gain. http://www.pipeinsulation.org/. Failed or wet polystyrene can probably be calculated as 0 insulation. The larger risk is a major leak when (not if .. when) there is a pipe failure from corrosion.
    Dec 2008
    Portugal
    48
    1,020
    And if the insulation gets liquid water or vapor water from atmosphere it will condense and solidify expanding because of the "hydrogen bridges" and ....bumm...
  1. Pipe diameter, real life and theory
    By gwm121 in forum Fundamentals
    Last Post: 24-10-2009, 04:53 PM
  2. Measurement of pipe lengths
    By batfink in forum Technical Discussions
    Last Post: 23-09-2008, 09:50 PM
  3. Burst Pipe caused by Abrasion. (aka Only on a Friday)
    By Grizzly in forum Chit Chat & Service Stories
    Last Post: 19-09-2008, 06:59 PM
  4. pipe insulation thickness
    By bangoman in forum Air Conditioning
    Last Post: 24-04-2008, 08:43 PM
  5. large refrigeration plant cooling tower issue
    Last Post: 25-03-2007, 01:35 PM
