Thread: problem with my Zanotti DFZ430
16-08-2010, 09:57 AM #1
hii
how are you ?
i have Problem in Zanotti Model DFZ 430 Problem A04 & A08 Please help me if u know the Error .
KiwA
18-08-2010, 02:18 PM #2
Re: problem with my Zanotti DFZ430
Hi Kiwa
Welcome to RE forums.
Code A04 is pressure switch (Occurs if either HP or LP has tripped).
Code A08 is starting failure/alternator not charging (Occurs after 5 start attempts, and if no output from alternator).
Hope this helps
Grahamen boca cerrada no entran moscas
MFI AMP6855 defrost problem
By gliderpilot47 in forum DomesticReplies: 4Last Post: 12-01-2011, 12:11 PM -
Fujitsu Multi problem
By BMS1 in forum Heat PumpsReplies: 15Last Post: 02-09-2010, 06:41 AM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
mycom 4wb unloading problem
By samlee12 in forum IndustrialReplies: 13Last Post: 19-01-2009, 10:21 PM -
Toshiba RAS 13 SKV problem....
By igi in forum Air ConditioningReplies: 17Last Post: 12-01-2009, 08:03 AM
