Results 1 to 10 of 10
Thread: Parts required
08-07-2010, 07:35 PM #1
Parts required
Good day one and all. I am trying to find a replacement defrost/ comp control for a Caravell 2 door upright display chiller. I have tried several places but they have not come back to me, or in the case of one lady did not know what I was talking about??????
Can anybody help please. All my emails are bouncing back from caravell UK as undeliverable. I understand they are the same as, or very simmilar to Scanfrost units.
I am in the UK.
08-07-2010, 07:44 PM #2
Re: Parts required
Why not try a Dixel Universal, they replace almost all OEM fitted controls, need a bit of setting up but not rocket science.
08-07-2010, 07:57 PM #3
Re: Parts required
Hi, it is not a controller but a sort of relay. 3 brass "fingers", common power feed to center, compresor on to one side, nothing on other, Motor turns cam which switches centre finger to either comp on or nothing. I assume it is a defrost timer of sorts. All inside a white plastic housing with a blue wheel/cam.
08-07-2010, 08:36 PM #4
Re: Parts required
flash compact 24hour will do the job.
09-07-2010, 07:55 PM #5
Re: Parts required
what your looking for is a microrex timeclock, however due to the way you have posted this thread, id recommend you phone someone who knows what they are doing!
09-07-2010, 10:14 PM #6
Re: Parts required
Before you start condeming people you should think. I have been in the game for a few years now, always employed by companies, and have just started out on my own. If I cannot find a supplier through the internet or on the phone, despite giving model numbers and manufacturers details from labels attached, I will ask people who might know. Just because I am asked to repair a piece of equipment that is new, to me, have found the fault and am unable to find a part means I don't know what I am doing??????????
In the mean time what makes YOU think you know what you are talking about. The maker of the part is nothing like microrex, or are you using a generic term, as in Hoover for vacuum cleaner etc
09-07-2010, 10:18 PM #7
10-07-2010, 03:55 PM #8
Re: Parts required
I am trying to find a replacement defrost/ comp control.
it is not a controller but a sort of relay. 3 brass "fingers.
the above are quotes from your post in order, surely i can be excussed for my reply, first its a controller, then its not, then its a wee brass thingy, then you assume its a defrost timer! well we all no the saying about assumption. also to answer the question in your last post a microrex timeclock would do the job perfectly, and by the way im more a dyson man myself!
11-07-2010, 10:37 PM #9
Re: Parts required
I now know that it is a off-cycle defrost timer, 8 hours running and 20 mins off. Perhaps my description was not the best but here is a picture of the replacement.
Please wait
Image not available
12-07-2010, 12:43 PM #10
Re: Parts required
hi, this timer is a supco adjustable timer you can buy these from RPW there part number is L038 list price £29.42, like i said above a simple microrex timeclock will do the same job cost you around £17 from climate centrer!
Bottle fridges, can you reccomend one with good parts support?
By Clk320_Greg in forum CommercialReplies: 24Last Post: 22-06-2011, 11:54 AM -
Thermokıng and carıer parts
By scrp2323 in forum TransportReplies: 0Last Post: 09-02-2010, 04:20 PM -
LG parts
By paul_h in forum Air ConditioningReplies: 5Last Post: 23-08-2008, 06:19 PM -
carrier spare parts
By coolingman99 in forum RefrigerantsReplies: 12Last Post: 21-03-2008, 08:36 AM -
Vintage Compressor Parts
By J.D in forum Industrial CompressorsReplies: 6Last Post: 04-08-2005, 08:07 PM
