    Apr 2010
    UAE
    12
    EKC 315A Strange Problem
    At work last night I faced a very strange problem, all the sudden ... 7 numbers of EKC 315A controllers stopped working properly.... They were all showing temperatures of 140C and above!!!! I connected on of them with a probe, and it was sensing temperature but as if it were adding 120C to the actual value!!!
    I am really clue less.. how can this happen, 7 numbers of EKC 315A at the same time!! and showing the same problem..
    I tried to reset one controller to original factory setting, and then loading the parameter, but still the same issue... Kindly help me A.S.A.P if anyone had the same issue before.
    and thanks in advance.
    Jan 2009
    58
    161
    Re: EKC 315A Strange Problem
    Hi quark555,
    Are these controllers connected to a network, if so what is the front end?
    One explanation would be a network error that has sent bad information to these controllers and caused the issue you have found.
    Jun 2007
    South Africa
    66
    120
    Several scenarios can exist!
    Do you have PT 1000 sensors on it?
    Did you connect the probe straight on the controller when testing?
    Did somebody cut probe cables by accident?
    What is the r05 parameter set to?
    What is the o30 parameter set to? Did it match the Refrigerant in use?
    What is the 017 parameter set to? Temperature? Superheat? Valve opening degree?
    Normally when probe wires are open circuit, they show high readings.
    Come back on this matter if possible.
    I am not always right, but I'm never wrong!
    Apr 2010
    UAE
    12
    Dear Silhouette,
    Yes they are connected through LanBus network. But I already isolated the controller, restarted it, and same result. (I don't know if restarting it should help). Suppose that it was network problem, how to resolve it? even though thel Lon Network is workig fine since that we are actually getting alaram normally and we can view all the different nodes.
    And thanks you in advance.
    Apr 2010
    UAE
    12
    Dear Eeram,
    Below my answers in blue.
    Yes PT 1000
    Yes I connected the probe straight on the controller while testing.
    No. (Actually I imagained that all the cables were going in one cable try a something happened over there.. but i
    C-b
    Yes it's matching the refrigerant in use.
    01
    Temperature?
    Superheat?
    (I used brand new probe while testing, and I checked its resistivity, and it was fine and normal)
    And thank you for your help.
    scotland
    756
    sounds like a power surge, i have had similar problem a few times when the building was hit by lightning, this was on elm controllers though,we had to replace about 20 controllers in 1 go.
    Apr 2010
    UAE
    12
    Thank you coolhibby for your reply. Actually I suspected that.. but unfortunately our BMS didn't register any power interruption. Thus we couldn't prove it for our management.
    scotland
    756
    hi quark this will be because the the bms system will have more than adequate surpression,a lanbus network nor the 315 controllers have any surpression!
  1. A strange problem
    By MuhengineeR in forum Air Conditioning
    Last Post: 27-10-2010, 05:21 PM
  2. Hitachi RAS-20FSG strange problem with fuse
    By ewgeny in forum Air Conditioning
    Last Post: 08-03-2010, 09:26 AM
  3. YORK YCAM B450 strange PCB problem
    By exxu in forum Trouble Shooting
    Last Post: 17-02-2009, 01:17 PM
  4. Strange compressor problem
    By Spoc in forum Trouble Shooting
    Last Post: 09-10-2007, 05:04 PM
  5. strange inverter problem
    By rbartlett in forum Air Conditioning
    Last Post: 19-05-2006, 08:31 PM
