Thread: Trane Centrifugal Oil sample
17-03-2010, 07:11 PM #1
Any suggestions on taking an oil sample on a Trane centrifugal chiller, should the sample be taken after the machine has run for a couple hours or is it OK to take the sample on a machine that has been off all winter?
17-03-2010, 09:43 PM #2
Re: Trane Centrifugal Oil sample
Off all winter would be the worst case sample so maybe be the better one to take.
Is there any reason why you can't take both?Brian - Newton Abbot, Devon, UK
18-03-2010, 02:01 PM #3
02-04-2010, 05:07 AM #4
I always took the sample in operating conditions, (so I would let it run). The suspended metals that they check your bearing wear with, would tend to settle at the bottom of the sump, (In my Opinion). I would check with trane though, especially if it is under warranty!
20-04-2010, 03:03 AM #5
depending on the model can take the sample, I suggest you take oil sample after winter preferably the oil sample taken after 72hrs of continuous operation
Trane Centrifugal Chiller
By iceman007 in forum Technical DiscussionsReplies: 6Last Post: 29-10-2009, 10:24 PM -
AEC Pinical chiller with trane comp
By cptrdbrd in forum CommercialReplies: 1Last Post: 28-10-2009, 09:47 PM -
centrifugal motor by trane
By goshen in forum Trouble ShootingReplies: 5Last Post: 03-05-2009, 06:48 PM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM -
Similarities (differences) McQUAY vs. TRANE
By Jacek in forum Air ConditioningReplies: 3Last Post: 01-04-2007, 09:46 PM
