Thread: daikin pcb problem
23-03-2010, 09:05 AM #1
daikin pcb problem
i do my own servicing for this daikin model
ftkd71jve
by removing the drainage tray and plugging out the swing louver motor, cleaning the rotor etc..
but after putting back everything, plug back the cables, try switching on but totally not moving
even though have reset the main power, the louver suppose to auto swing back into position, but is not moving either.
what is happening here?
this is not the first time i'm doing it.
any advice??
23-03-2010, 10:04 AM #2
Re: daikin pcb problem
Motor drive and louvre spindles all lined up and connected?
23-03-2010, 01:44 PM #3
23-03-2010, 01:55 PM #4
27-03-2010, 01:54 PM #5
if you plugged the loads back into the printed circuit board with the power on you may have damaged the printed circuit board.
27-03-2010, 02:05 PM #6
27-03-2010, 02:08 PM #7
if the unit power was on this can damage the board and motor.
30-03-2010, 03:09 PM #8
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
problem with DAIKIN FCQ 71 > i need technical book
By mimifrigo in forum Air ConditioningReplies: 7Last Post: 13-01-2010, 03:06 PM -
DAIKIN problem
By mimifrigo in forum Air ConditioningReplies: 3Last Post: 05-01-2010, 09:02 PM -
Daikin or Mitsubishi
By eloroncedark in forum Air ConditioningReplies: 25Last Post: 11-08-2008, 03:01 PM -
DAIKIN problem ?
By AaronX in forum Air ConditioningReplies: 11Last Post: 12-10-2007, 02:19 PM
