Results 1 to 48 of 48
Thread: SR2 download
18-01-2008, 02:33 PM #1
SR2 download
My 1st post here.
SB 210, download only shows power up time, fault codes and set point. Does not show return and discharge temps. like it should. What is set wrong? I'm thinking a cold start would put it back right.
18-01-2008, 04:45 PM #2
Re: SR2 download
You downloaded through the Cargo Watch, port.
Download the data through the service watch port.
If you want info from the HMI Cargo watch, you will have to set it up through wintrac much like a DAS. You may need to go in and turn on sensors to be logged on through wintrac in the HMI.
But regardless Service watch will tell you no tales, and if you have technician user level enabled. you will get alot more technical data.
In your wintrac program there is a help tab window, it lists detailed instructions on how to turn on sensors to log and any other data that you want to see.
Regards A-ZLast edited by absolute-zero; 18-01-2008 at 04:49 PM.
19-01-2008, 01:27 AM #3
Re: SR2 download
I did download from service and cargo watch.
Cargo watch needs the extra sensors in the back to work? Cargo download has a column in tabular view for sensors, but nothing is there.
Service watch download does not even have the columns for sensors. It was setup to poll every 10 min. for return, discharge, ambient, and coil, but does not show up in graph or tabular view.
Wintrac is on admin. level, which I believe is above technician level. I have been all through the help section of wintrac, and most of the sr2 "green" book with no luck finding a solution.
This was a over the road repair, and most likely will never see this unit again. Trying to understand all this for future reference.
19-01-2008, 01:39 AM #4
Re: SR2 download
What version of wintrac are you using? You will need 4.4 version or higher for SR2 single temps and 4.6 SR2 multi-temps.
i noticed you said admin level. I have never heard of that level for wiintrac, but I have seen it in ReeferManager.
Find out the version by clicking on help about wintrac. a new window will pop with version you are running.
A-Z
19-01-2008, 01:41 AM #5
19-01-2008, 01:50 AM #6
Re: SR2 download
19-01-2008, 02:00 AM #7
Re: SR2 download
Hey dabutcher,
I just sent you an email, just reply to it with attached wtf files, i will take it from there.
19-01-2008, 02:09 AM #8
Re: SR2 download
Good assist a-z, you're the man on this case ! See if you can use " The Knack" - was that you in the cartoon?
Yuk Yuk
Let us know what you dig up. I gather from DaButcher it's an out of state trailer. Is it under any service contract ?
have a good w/e
T-PRemember what Augustus once said:
"festina lente" - make haste, slowly!
19-01-2008, 02:36 AM #9
19-01-2008, 02:51 AM #10
Re: SR2 download
Gooood one a-z!
Maybe that kid was you as a child. The industry needs more like ye to come along - not alone with great skills & aptitude but positve attitude as well.
b.t.w Thanks for your post on Fred McKinley Jones , the industry founder.
Did not get point of Frank's reply though about thousands losing jobs because of it - invention of transport temp control created an industry while opening up the world to availability any time anywhere of foods and other perishables.
best regards
19-01-2008, 03:03 AM #11
Re: SR2 download
Hi Dabutch Thanks for the downloads,
I have taken a brief moment to review them.
Couple obviouse things i found right out of the gate.
Service Watch rev was B002
Cargo Watch rev was 6501
I am finding no where in the data that anyone has ever went in changed the logging, however I did find the HMI had corrupted data stored in it dated back May 11 2007 at 9:00 pm till 11:30 pm.
Some one has serviced this controller before based on revisions, in both HMI and controller. Plus time stamps do not match. I see logged data in service watch back to Jan 06, and may 07 for cargo watch.
Nothing Jives, perhaps the HMI was replaced or somone got to messing around with the unit in wintrac and shut off all logging, or there is a software to hardware conflict.
I would make the reccomendation of flashloading the service watch to B007 rev. and Cargo watch HMI to 6512 revision, make sure clock setting is correct in HMI, then perfrom a long PTI,
Using wintrac go into sensor tab when communicating with service watch, set all supported unit sensors and analog / digital inputs to log both time and event. Be sure to save the changed settings in service watch.
Let run for an hr, then perform another long PTI, after it completes that wait a few minutes and enter a Start of trip, wait 15 minutes then download the service watch, to see if all data is there and the PTI and start of trip is there.
Regards A-Z
19-01-2008, 03:10 AM #12
Re: SR2 download
I did mess around with things as a kid all electriacl and even mechanical, i wasnt smart enough to build a ham radio, But i did know how to charge up a capacitor with AC 120 voltage and let my lil sis or brother pic it up to give me as a prank, i think i only pulled that stunt once when i was 9 and my dad found out, he kicke4d my ass.
Im not sure what all the lost jobs meant either, maybe he was refering to farmers cooton Ginnys and there horses dated back before the transport refrigerated days.
Its no big secret that machines take the place of many working people.
Regards A-Z
19-01-2008, 03:22 AM #13
Re: SR2 download
Hey Dabutcher
Based on your avatar pic, I think its time you upgraded to TK EON!!!!!!!!!
19-01-2008, 04:18 AM #14
Re: SR2 download
Thanks for your help A-Z, wish I would have had time to update that unit. Owner had a bad load claim on 12-29 and all he wanted was to prove or disprove if reefer was responsible. Of course the driver was pushing me to finish to make his next appointment.
By this download, I could not determine much to help him with the claim one way or the other, except set point was at 35 deg. and no faults occurred.
19-01-2008, 04:21 AM #15
19-01-2008, 04:55 AM #16
Re: SR2 download
Geeeze is that what the avatar is ? ,,,, a bashed battery! I was gonna ask DaButcher before a-z brought it up .
I thought it was an old reefer box that had been hit by a train ! LOLRemember what Augustus once said:
19-01-2008, 07:06 PM #17
Re: SR2 download
Did you open the doors of a reefer to find that? Or was it somone using an open flame around it when it was being recharged?
I have my hypothesis as to why batteries explode, but, I sure hope no one was injured or around that when it happened.
Glad i was able to help understand the SR2 and what it was doing. I am sure its nothing you did, that cause the download to look like that, My guess would be somone replaced the HMI version A with a version B, and never updated the software for the Hardware change.
As i was looking at the download I did see the obvious signs that the unit was stuck on stupid, meaning, I saw alot of power ups repetatively, this was caused by HMI and controller trying to comminicate and introduce each other through the CAN, with 6504 revison and older, typically the unit could constantly cycle in and out of unit configuring on power ups, it was glitch in the software but TK fixed in 6504 rev. I also saw other issues in the download but not important.
I believe 6507 or higher would have fixed all those issues that I saw in the download.
the present S/W that is now being used is 6512, and is the prefered S/W that should be used, that will have the same instructions to correct the issue, along with correcting some other interface issues in both single temp and multi-temp SR-2 applications.
Have good W/E
regards A-Z
20-01-2008, 07:11 PM #18
Re: SR2 download
T-P, Dabutcher,
thanks for the rep points. I however noticed they have not appeared.
I wonder whats up with that?
A-Z
20-01-2008, 10:52 PM #19
Re: SR2 download
Opened the door and found it. In the last two years have seen more than two dozen TK batteries that have exploded. Heard two of them, both had low voltage and exploded when starter engaged. All were on TK units, none on CTC units. All the blown batteries were relabeled Interstate batteries. BTW Interstate is no longer the supplier of TK batteries.
20-01-2008, 11:01 PM #20
Re: SR2 download
Tried to post another pic of the battery. Have to have 15 post to do that. Hang on for a mini flood from DaButcher!
20-01-2008, 11:02 PM #21
Re: SR2 download
Tried to post another pic of the battery. Have to have 15 post to do that. Hang on for a mini flood from DaButcher! 7 more
20-01-2008, 11:02 PM #22
Re: SR2 download
Tried to post another pic of the battery. Have to have 15 post to do that. Hang on for a mini flood from DaButcher! 6 more
20-01-2008, 11:03 PM #23
Re: SR2 download
Tried to post another pic of the battery. Have to have 15 post to do that. Hang on for a mini flood from DaButcher! 5 more
20-01-2008, 11:04 PM #24
Re: SR2 download
Tried to post another pic of the battery. Have to have 15 post to do that. Hang on for a mini flood from DaButcher! 4 more
20-01-2008, 11:04 PM #25
Re: SR2 download
Tried to post another pic of the battery. Have to have 15 post to do that. Hang on for a mini flood from DaButcher! 3 more
20-01-2008, 11:05 PM #26
Re: SR2 download
20-01-2008, 11:05 PM #27
Re: SR2 download
Tried to post another pic of the battery. Have to have 15 post to do that. Hang on for a mini flood from DaButcher! 2 more
20-01-2008, 11:06 PM #28
Re: SR2 download
Tried to post another pic of the battery. Have to have 15 post to do that. Hang on for a mini flood from DaButcher! 1 more
20-01-2008, 11:09 PM #29
Re: SR2 download
I havent seen that many blow up, up here in the north east but I would may suspect that high ambients were involved. TK is no longer using IB as there primary battery vendor, they have gone to exide, and also are now utilizing the EON battery.
I have many customers that will vouch for the EON battery in my area as it has proven its worth here in the north east, in regards to low mainteannce, no corrosion factors, lifecycle, increased reserve capacity, dry cell technolgy doesnt freeze in winter, battery slowly shows signs of wear in all starting conditions over the course of its life, unmatched 4yr full lifetime warranty.
I can keep going on and on about this paticular battery. The battery is worth its weight in gold.
Regards A-Z
20-01-2008, 11:10 PM #30
20-01-2008, 11:13 PM #31
20-01-2008, 11:15 PM #32
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
20-01-2008, 11:16 PM #33
Re: SR2 download
The only negative i heard on the battery was the weight comparison, especially when trying to install in a Super II multi-temp with deep sump 7 qt compressor. But the customers here think thats a small trade off. in comparison to battery failures and breakdowns, i guess you cant put a price tag on piece of mind.
Regards A-Z
20-01-2008, 11:25 PM #34
Re: SR2 download
Yeah dead batteries on an after hr callout can be beneficial to the wallet for a technician, I know it was for me
But the world and there specific regions recognize issues that cause customers grief, and this make engineers working harder in providing solutions to these griefs in added value to specific product lines.
The good news is hopefully techs wont have to get all dirty any more mechanically fixing every issue, but more so fix them logically and or through the web based tracking systems.
I dont see that happening next week but, however it is a nice thought.
As long as equipment is still needed and runs or operates mechanicaaly by its basic root design we will all need to continue to service the stuff.
regards A-Z
21-01-2008, 06:47 PM #35
Re: SR2 download
Very cool, glad no one was around it when it happened.
I remember years ago working on a CBci system early max 502 sytem, clean up, requiring 12vdc to run fans and est. I had migshift 214 compressor and electric motor at the time with a henry clean up kit. I used a battery charger to maintain vehicle batteries whil running the process, severla hours on clen up i noticed a smell from the other end of the shop, and 30 seconds later the I heard what sounded like a cannon going off.
This was my first expierence of battery explosion.
Luckily no one was in the are when it happened.
I have always heard of the potentiols of this happening and it was after that day I gave Batteries the respect of the fatal or near fatal possibilties.
A-Z
22-01-2008, 01:16 AM #36
22-01-2008, 01:56 AM #37
08-02-2008, 05:40 PM #38
Re: SR2 download
if you have not figured it out yet you are not in tech mode or engineer mode of wintrac,eng mode will give lots more data
08-02-2008, 07:10 PM #39
Re: SR2 download
Hi tkjim,
I reviewed the download that, Datbutcher sent me a week or two ago, it apperars that somone turned off all the logging data in the service watch base controller.
Regards A-Z
Ps glad to see another TTC professional member here. I look forward to reading your posts.
08-02-2008, 09:23 PM #40
08-02-2008, 10:50 PM #41
Re: SR2 download
i dont think its a multitemp prob
in europe (germany, switzerland)thers no prob with blown batts
i think its a manufactoring prob
TDI
08-02-2008, 11:12 PM #42
08-02-2008, 11:18 PM #43
Re: SR2 download
Thats because TK remote evaps use 12-14 vdc fans, where ctc uses the AC martinator to provide high voltage ac voltage to the remote fans.
TK uses 120 amp alternator to handle the electrical load for remote evaps, New SR2 MT expansion module is smart enough to control fan speed through electrical current load, depending on specific configs mainly speaking of Z configuration, which will be S-6 PE in both second and 3rd zone, holy moly talk about current, imagine 12 fans running all at once at full current!!!!! Thank goodness for the expansion module
A-Z
08-02-2008, 11:41 PM #44
Re: SR2 download
ok in europe sr2 mt will be released in Q4 2008
but i dont think with z2 and z3 @S6
rather with S3 in z2 and z3
now it is as follows:
SL MULTI-TEMPERATURE
SYSTEM SELECTION GUIDE
Good Practice
Maximum Number of Fans per System:
• The trailer host will support a maximum of six evaporator
fans
16-02-2008, 01:24 PM #45
Re: SR2 download
Dear All ,
I'm M&E Engineer from Singapore. I would like to know about VRV System ebook , free download website .
12-02-2010, 08:14 PM #46
Re: SR2 download
hello I could send the software
my mail : sam_Virgo_123@hotmail.com
14-02-2010, 10:10 PM #47
Re: SR2 download
very rare to see a battery explode on tk multitemp here in UK,i look after 150 SL Spectrum S6 Parallel evap,now got 6x SLX Spectrum S6PE,we use a Varta wet cell battery,but dont suffer the extereme weather conditions as in North America,
as far as wintrac is concerned you should have 4.6 or higher to work effectivly with SR11
15-02-2010, 02:43 PM #48
Re: SR2 download
merciiiiiiiiiiiii
compressors book (free download)
By johnyfreon in forum Refrigeration BooksReplies: 99Last Post: 15-08-2011, 10:12 AM -
Dakin Download
By superswill in forum Trouble ShootingReplies: 9Last Post: 14-06-2007, 10:04 PM -
anyone have a site where i can download an a/c calculator for sizing a ducted system
By frosty74 in forum Air ConditioningReplies: 2Last Post: 31-03-2007, 09:54 AM -
service manual download site
By chilly in forum FundamentalsReplies: 2Last Post: 12-09-2005, 09:38 AM
