Thread: propane V/s propylene
20-01-2010, 11:53 AM #1
can any body tell me that whether propane or propylene will be a better refrigerant for using in a system at -35 degree evaporating temperature??
26-01-2010, 10:16 PM #2
Re: propane V/s propylene
Assuming -35ºF and 90ºF condensing temp
R-1270 R-290
Evap -34 -34 ºF
Cond 90ºF 90 ºF
Liquid Enthalpy -13.206 261.59 btu/lb
Vapor enthalpy 97.731 368.2 btu/lb
Vapor entropy 1.4085 1.3649 BTU/lb-R
Suction pressure 23.62 18.562 PSIA
Condening press 199.8 165.58 PSIA
Compression ratio 8.46 8.92
Refrigeration effect 110.937 106.61 btu/lb
Mass flow rate 108.1695 112.5598 lb/hr/ton
Ideal Compression
Discharge enthalpy 143.61 141.35 btu/lb
Compressor work 45.879 43.15 btu/lb
4962.71 4856.96 btu/hr/ton
Efficiency 1.95 1.91 hp/ton
Ideally propane is sightly better, The compression ratio of propane is higher than propylene so the compressor efficiency is lower. Infact they are almost identical.
You will have to look at the compressor efficiency curves to get a better answer.Last edited by Dacosta; 11-02-2010 at 06:51 PM.
26-01-2010, 10:18 PM #3
Sorry my post killed my formatting
10-02-2010, 09:38 PM #4
Hi, Dacosta
... you can always edit your post and change formatting to make it easier for reading
Best regards, Josip
11-02-2010, 06:52 PM #5
Thanks i can edit now but it still takes out all my spaces to put it into nice column like format.
propylene refrigerant criteria
By zhouweidl in forum HydrocarbonsReplies: 3Last Post: 30-07-2009, 01:01 PM -
DIY Install ~ R290 (Propane)
By Makeit go Right in forum Air ConditioningReplies: 9Last Post: 23-09-2007, 10:34 PM -
Propane Refrigerator Conversion
By zolar1 in forum RefrigerantsReplies: 26Last Post: 04-02-2007, 03:42 AM -
propane compressor suction drum
By Ahmed_LNG in forum RefrigerantsReplies: 7Last Post: 01-01-2006, 08:01 AM -
By Ahmed_LNG in forum Trouble ShootingReplies: 0Last Post: 30-12-2005, 06:08 AM
