Results 1 to 16 of 16
Thread: CO2 Systems
    Aug 2001
    1,046
    CO2 Systems
    There?s a lot of interest in CO2 systems, particularly in cars to replace HFCs.
    Having spent my working life with the more traditional systems, it?s not a subject I?m knowledgeable about, so can anyone help me with a brief explanation of the process?
    I?m making the assumption that the process is trans-critical. Is this so? If not how is the liquid stage managed?
    What sort of pressures are we looking at?
    Any help is much appreciated.
    ________
    herb scales
    Jan 2004
    Southern California
    7
    Re: CO2 Systems
    Please clarify CO2. We use CO2 (Carbon Dioxide) as a once through cooling media what are you refering to? our terminology seems to be different.
    Dec 2002
    Malaysia
    59
    86
    22
    Re: CO2 Systems
    Yes, the same CO2 or technically in Refrigeration known as R744.
    Yes, the condensing pressures are in the trans-critical stage.
    Pressures are very high ( -5 C evap is about 30 bars)
    Special condensor design and piping design are required to manage the high side.
    Have some material at home somewhere if you're interested.
    Aug 2001
    1,046
    Re: CO2 Systems
    Thank you for the replies.
    I am familiar with direct discharge systems in transit storage. That was not what I had in mind.
    My question was about the CO2 mechanical cycle that is appearing as an industrial alternative to HFCs and to its extended use in MAC.
    Pressures are a prime consideration. What happens on the high side? Is it transcritical in practical use or is there a condensation stage and if so, what are the typical pressures / temperatures? What is the cooling medium?
    A description of a typical cycle used in an actal installation would be useful.
    ________
    herbalaire
    Mar 2004
    Denmark
    65
    Re: CO2 Systems
    Hi Argus
    Maybee this can help You.
    http://www.mst.dk/homepage/default.a.../kap02_eng.htm
    Best regards
    Carlo
    Dec 2002
    Malaysia
    59
    86
    22
    Re: CO2 Systems
    Carlo,
    That was helpful to me.
    Bernard
    Mar 2004
    Denmark
    65
    Re: CO2 Systems
    happy to help, I have some new things about CO2 in mac systems. Diagrams, test conditions , HX, etc.
    The description is in PDF and is to big to bring in this forum,-1.2 MB and 0.6 MB. If anyone would like to see them. just mail me, and I will mail back, direct to you.
    Best regard
    Carlo
    Peterson's Avatar
    Peterson Guest
    Re: CO2 Systems
    For CO2 refrigeration system info, please visit my website. There are several research links you can make understand about that.
    http://www.geocities.com/krasaein
    Jun 2001
    N.Ireland
    1,630
    Re: CO2 Systems
    Quote Originally Posted by Argus
    Argus the system you are thinking of is not trancritcal.
    The high stage R717 or 404a system is simply in design a glycol chiller, only it condenses co2 instead of cooling glycol. It is also possible to pump the liquid co2 from the condenser outlet around a chill load and back to the vapour connection on the condenser, this puts load on the high stage system to cool the volitile secordary (the pumped co2) but not the low stage co2 system, which is simply a pumped co2 system, ver like a pumped R717 system. Condensing of the co2 takes place at -8 to -14 deg C, by virtue of the R717 (R404a) high stage system evaporating off.
    Not much like thre theretical systems seen on student sites
    Very like an ammomia glycol system on the high stage and an ammonia pumped system on the low side (on steroids) with co2 instead of ammonia.
    Hope this helps.
    Kind Regards. Andy.
    Jul 2001
    Sydney, Australia
    753
    Re: CO2 Systems
    just posted some pics of r744 supermarket rack under supermarket forum if anyones interested
    Jun 2001
    N.Ireland
    1,630
    Re: CO2 Systems
    Quote Originally Posted by 750 Valve
    750 Valve,
    nice looking system, all stubs probably to keep pipe sizes and then wall thicknesses down.
    Kind Regards, Andy
    Feb 2006
    Mauritius
    22
    Re: CO2 Systems
    Hi!
    I know that Coca-Cola has been developing bottle coolers that works on CO2 for some time now.
    Latest news I had is that Sanyo compressors were the only one that could do the job, and samples have been tested already.
    Have anyone got some information about same?
    Mar 2004
    Denmark
    65
    Re: CO2 Systems
    Hi Arkay
    As you said Sanyo made this bottle cooler for Coca Cola and they has now a heat pump running on CO2.
    Danfoss has made a small CO2 compresser for test in small aplications.
    http://www.sanyoaircond.com/comune/d...dwld/e_C02.pdf
    http://www.ecn.purdue.edu/Herrick/Ev...ku-shimada.pdf
    Best regards
    Carlo Hansen
    Nov 2004
    Sri Lanka
    77
    Re: CO2 Systems
    Quote Originally Posted by Carlo Hansen
    Best regard
    Carlo
    Dear carlo Hansen
    Re CO2 Please let me know you E mail address or Mail to patrickj@time.net.my
    Jun 2004
    Finland
    136
    Re: CO2 Systems
    Car a/c systems also start to convert to co2, here's Denso's co2 a/c for passenger vehicles:
    http://www.theautochannel.com/news/2...04/151245.html
    http://www.sae.org/automag/techbriefs/04-2002/page2.htm
    Regards,
    Nova
    issachaer's Avatar
    issachaer Guest
    Re: CO2 Systems
    Best regard
    Carlo
    Carlo,
    I would be grateful if you could e-mail me the Co2 Pdf files.
    My e-mail is
    issa_chaer@hotmail.com
    Kind Regards
    Issa
  1. contaminants in ammonia systems
    By Johnny Rod in forum Refrigerants
    Last Post: 17-10-2011, 05:26 PM
  2. My local Apprentice Training Classes
    By shogun7 in forum Training
    Last Post: 17-03-2007, 03:10 PM
  3. Refrigeration alarm systems
    By tonydeith in forum Supermarket Refrigeration
    Last Post: 27-04-2006, 01:43 AM
  4. HFCs for flooded systems?
    By garyb in forum Refrigerants
    Last Post: 21-04-2006, 10:02 PM
  5. Diy Systems
    By kewlman in forum Air Conditioning
    Last Post: 22-07-2005, 01:08 AM
