    Jan 2009
    Greece
    Samsung inverter a/c trouble
    Could anuone please help and tell me in samsung inverter air conditioner when you power the device all the lamps on front panel start blinking! I took the power cords out and let the device for 30 min to reset(?) but nothing! The problem remain. You give power and all start blinking! The problem occured when we had a power brake down but the unit was not working!!
    Split Croatia
    6,151
    Jan 2009
    Greece
    Re: Samsung inverter a/c trouble
    Maube i should tell that it do not work from the front panel either. So you tell me that i go through the option codes in the remote controller and it will start up?
    Apr 2006
    stafford
    42
    974
    follow the advise nike has given and will resolve the problem
    Paul
    "KEEP IT COOL"
    mehen's Avatar
    mehen Guest
    well open the compressor panel and note the error displayed on the PC board.
    Refer to the installation manual & troubleshoot the unit!
    Jan 2009
    Greece
    If i had an installation manual i would already done it...or the troubleshooting codes!! The problem was solved with nikes codes!!!! Thanks anuway...and special thanks to Nike!!
    Split Croatia
    6,151
    Quote Originally Posted by john.sikiotis View Post
    Don't forget to add reputation!
  1. SAMSUNG Inverter Errorcode E4
    By samsunginverter in forum Air Conditioning
    Last Post: 05-08-2009, 11:28 AM
