    70
    4,703
    47
    Leaking Rotalock
    This one would fit either the Industrial or the Supermarket sections.
    Anyway I must be going through one of my "Lucky" periods.
    Are you sitting Comfortably!!!
    Basically I was working on a Bitzer pack with three screws,changing the oil filters.
    This pack suffered a major leak recently.
    It was one of those sites where you get the "we have done nothing" Answer!
    ( now please wash your hands after visiting the toilet. Is in 5 different languages!)
    Anyway none of us could find the leak and having been recharged. Has been running OK for several months!
    So I am kneeling on top of the pack, between comp1 and 2. Shutting the discharge valve.
    When I shift my weight from one knee to the other, (as you do!)
    I put out my left hand to balance, touching the liquid line going into the Economiser port on comp1.
    The pipework moves, it is loose!!!
    Basically what I discovered is whenever comp 1 is running and has reached a evaporating temp below approx -30c.
    Its economiser port rotalock was contracted enough to make it loose and leak!
    Whenever it warmed or unloaded pipework became rigid and gas-tight.
    Like I say another moment of pure luck!
    Although Monkey Spanners and others have touched on similar stories.
    I felt it was worthy of mentioning as I am sure similar will happen again to someone!
    And someone may "benefit from the story.
    Cheers Grizzly
    Split Croatia
    6,151
    Re: Leaking Rotalock
    Nice one! I will try to remember it.
    3,853
    I found this while looking for tightening torques for valves and meant to post it but can't remember if i did now....
    www.ecopeland.com/literature/eCopeland/EN_Scroll%20replacement%20Guidelines_0.pdf
    Makes interesting reading, copeland recomend thread lock on the rotalock threads.
    I want one of the special tools but have yet to see one for sale anywhere
    Jon
    Split Croatia
    6,151
    Some advise given to me when I was started in this trade and first time saw rota-lock.
    When opening and closing them, engineer should first loose stem nut by 1/2 turn and then manipulate valve.
    Then when manipulation is over, stem nut should be tighten again for 1/2 turn.
    That reduces wear and tear at stem and reduce leak at stem to minimum.
    70
    4,703
    47
    Thanks for the input guys. I tried to delete the post this morning as reading it again seems a bit self indulgent.
    For some reason it would not clear?
    Anyway I went back to the site today.
    When everything was nice and cold.
    I checked all three rotalocs.
    Guess what the other 2 nipped up.
    In fairness this plant has been running for nearly 6 years.
    With all the expansion and contraction that the valve has been subjected to.
    I am not surprised they had loosened a little!
    Lovely little screws but Harmonics may be an issue.
    Thanks for the tip Nike.
    I agree with you MS the crows foot I understand, but what is that they are using to counter-lock the valve.
    Looks like something that has been fabricated?
  1. Future FFM90 leaking water, no fan
    By ahughes3 in forum Domestic
    Last Post: 15-07-2010, 11:54 PM
  2. Frick shaft seal leaking
    By Ian B in forum Industrial Compressors
    Last Post: 27-01-2009, 10:31 PM
  3. Rotolock or Rotalock
    By BESC5240 in forum Commercial
    Last Post: 14-11-2008, 08:15 PM
  4. Replies: 2
    Last Post: 12-10-2008, 09:41 AM
  5. Leaking X430LS shaft seals
    By reefermadness in forum Transport
    Last Post: 02-04-2006, 08:00 PM
