Results 1 to 10 of 10
Thread: seawater heat pump
Threaded View
17-09-2009, 07:51 AM #10
Re: seawater heat pump
the titanium needs good filtration because the sand is abbrasive to it.
on board a lot of heat exchangers are used with seawater , all types are present, like shell tube and plate. filtration is not done n ships (no room) however on land i would use a big pond to have the sediment out and maybe a filtration in series. The pond costs nothing and is a good filter.
Try to get the water as low as possible and upstream from the outlet. on board and in port we use starboard as intake and portside as outlet.computer shooter
paul deelen
+31653300739
Basics or is it?
By Fett in forum FundamentalsReplies: 17Last Post: 10-09-2009, 01:45 AM -
Heat pump hot water system
By kiamaian in forum Technical SpeculationsReplies: 4Last Post: 16-06-2009, 06:48 AM -
Pool heat pump water side diagram
By nike123 in forum Heat PumpsReplies: 23Last Post: 22-03-2009, 07:42 PM -
frostles heat pump
seawater heat pump
By Lc_shi in forum New TechnologiesReplies: 9Last Post: 26-11-2005, 12:30 AM
