    Rbarnes's Avatar
    Rbarnes Guest
    Daikin Noisy Drip Tray Pump
    Hello I hope somebody can help. I have moved into a flat that has 3x Daikin FT25GZVINB and 1 x FT35JZVINB, they chill very well, but two of the unuts ( in the main bedroom and lounge inevitably!) Have very loud drip tray pumps that are so load as to make the units unusable. Has anybody come across this problem? is it possible to drain the drip tray to a tank and therefore not need the pumps? Or is this a common problem and new pumps will fix?
    Jun 2009
    East Anglia
    204
    Re: Daikin Noisy Drip Tray Pump
    Quote Originally Posted by Rbarnes View Post
    Am trying to PM you but cant find the option....
    Do you have an email address?
    Those units do not have a built in drain pump, they have an additional pump to remove the water.
    New pumps may fix it as long as good quality ones are used.
    In the short term you might be able to use the gravity drain hose from the units and drain it into a bucket until you have the pumps resolved.
  1. Noisy Daikin VRVIII 3 pipe BSVQ boxes
    By hyperion in forum Heat Pumps
    Last Post: 25-02-2010, 01:49 PM
  2. Daikin lift pump
    By Slim R410a in forum Air Conditioning
    Last Post: 13-07-2009, 11:12 PM
  3. SILENCER FOR NOISY Payne HEAT PUMP
    By RODA in forum Heat Pumps
    Last Post: 24-02-2009, 04:22 PM
  4. DAIKIN Drain Pump
    By 2007eng in forum Air Conditioning
    Last Post: 03-04-2008, 01:54 PM
  5. Daikin drip tray
    By Andy AC in forum Air Conditioning
    Last Post: 08-11-2007, 08:55 PM
