Thread: vacuum on suction side
24-03-2009, 02:58 PM #1
I've got a 2 ton mini split with inverter that sometimes works great and other times the suction pressure will go super low and cause a fault code for low refrigerant or bad 4 way valve
I have 3 of these and they all do the same thing I know there not low on refrigerant i've reclaimed & reweighed
does this sound like a low ambient problem? outside temp about 50 fahrenheit these are all new units and are supposed to be rated to 4 fahrenheit for cooling mode
Does anyone have any idea's any help would be greatlly appreciated thanks
24-03-2009, 06:00 PM #2
Re: vacuum on suction side
definatly a low ambient prob
25-03-2009, 02:54 PM #3
Thanks for the reply! I suspected low ambient problem so I moved one condensor indoors where it should stay 80+ fahrenheit.
I'm going back there today to check on it and hopefully move the other inside as well.
I will post results here.
what is useful of Economizer?
By Ahmed.ragab in forum Industrial CompressorsReplies: 33Last Post: 18-08-2010, 12:15 PM -
Liquid charging through the suction side
By deu58 in forum FundamentalsReplies: 13Last Post: 02-07-2010, 05:23 AM -
Service Procedures For TK Scroll
By absolute-zero in forum TransportReplies: 0Last Post: 03-02-2008, 07:42 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM
