Results 1 to 20 of 20
    Oct 2003
    5,630
    Broken compressor
    Some pictures, compressor 1 month old.
    Not for sensitive peoples.
    Freezer applicaton Copeland
    Liquid slugging, ***** wash-out.
    Afbeelding (5): piston twisted in the cylinder
    Afbeelding: right piston is gone.
    Aug 2001
    1,046
    Re: Broken compressor
    Certainly a gruesome sight. Was that Coppper plating I saw on the piston head? That would indicate moisture presence to me.....
    Certainly looks like a dry set of bearings on the bottom end and the crankshaft.
    I have encountered similar failures in air cooled air conditioners that were grossly overcharged. The first the manufacturer knows is a waranty claim.
    The scenario goes like this.....
    1. Some idiot packs a double or treble charge into the unit. (Remember, packaged A/C has no receiver and operates on a measured charge).
    2. In winter months the unit shuts down over a weekend.
    3. When the building temperature decays and stabilises, there is likely to be a TD of 15 degrees C or more between the in and out sections.
    4. The refrigerant in the indoor section migrates to the outdoor unit.
    5. It fills the condenser, overflows and runs down the discharge pipe by gravity.
    6. If it overflows the muffler and settles on top of the piston / valve assembly the rapid expansion when the compressor restarts and injects hot gas into this body of static cold liquid will split a piston or connecting rod and sometimes blow a muffler apart.
    Far fetched? It happens and the usual explanation is a bad batch of compressors?.. When the real problem is hydraulic damage due to overcharging and bearing failure due to liquid washing.
    Seen it many times. Peter.
    ________
    Mercedes-Benz 300SEL 6.3 history
    Ooops........
    Sep 2003
    ISRAEL
    72
    4,248
    Unhappy Re: Broken compressor
    sorry about your compressor, peter.
    one of the ways to avoid these situations is to keep the system heated at all times.
    a 200W heater in the crankcase, and a 170W heater around the liquid saperator.
    everything on the pictures is related to liquid entering the compressor.
    another helpful thing that I do, is checking that pumpdown realy empty the system.
    chemi
    Jun 2002
    628
    Hi peter
    What application was the compressor running pack/single unit(CU).etc
    Regards Mark
    Oct 2003
    5,630
    Quote Originally Posted by MarkFiddy
    Hi peter
    Regards Mark
    Single unit, remote KUBA condensor on a KUBA SGB evaporator.
    Not very nice after some weeks.
    Perth, Australia
    87
    It will be interesting to see how Trane with their ceramic bearings and TurboCor with their magnetic bearing compressors get on. It would certainly make life easier to not have any oil in the system.
    Mark Baker
    rbartlett's Avatar
    rbartlett Guest
    a good engineer would have got that running again till the new one arrived ;-)
    cheers
    richard
    Oct 2003
    5,630
    Talking Re: Broken compressor
    Quote Originally Posted by rbartlett
    cheers
    richard
    No problem with that: when I arrived, it was running really smooth, no vibration at all, (very) low discharge temperatures, low discharge pressures, AMPS low, so... why in fact looking at it ?
    So.. am i a good engineer now?
    It was running this way for some days.
    It was due to a sump full of WD40 that it was running that smooth.
    Sure I have WD40: a good friend of me is working at the sole Belgium importer of that stuff.
    Ever tried this ? Spray WD40 on the thread of a light bulb, screw it in the socket, put in the wall socket and immerse the bulb completely under water. Light will light under water and normally, no safety device will trip at all.
    Try at your own risk but that's the way he always impresses customers.
    Mar 2002
    San Francisco Bay Area
    180
    Quote Originally Posted by Peter_1
    A bit off topic here, but I have cleaned up enough gummed-up sliding doors on deli cases, roller tracks on reach-in doors, etc. that I am not a big fan of the stuff. I carry food-grade silicone spray and teflon spray lube, both excellent DRY lubes that will not attract dust and turn into a gummy mess. I carry "liquid wrench" for loosening stuck/rusted screws & bolts and turbine oil for lubricating motors.
    But thanks for the info. If I ever need to do some underwater illumination, it sounds like just the thing! Maybe all those people electrocuted by hair dryers in the bath should be giving the things a good spray with ol' WD40 before jumping in the tub!
    Rog
    5,667
    Would you have this in QUICKTIME format
    Nov 2003
    NSW, Australia
    40
    242
    INOX, any of you guys other then aussies heard of inox? its based on lanolin and made in australia - i prefer it to a can of wd40, seems thinner and gets into all those nice rusted nuts and bolts good, available in a bottle or pressure spray can like wd40. also great for bearings frees them up a treat compared to wd which makes them feel binding through the tacky oil.
    not suitable to sliders etc as Rog approach is still the best for those applications.
    "Old fridgies never die, they just run out of gas!"
    rbartlett's Avatar
    rbartlett Guest
    [QUOTE=Bones]INOX, any of you guys other then aussies heard of inox? its based on lanolin and made in australia -
    yes but they were never the same since hutchence topped himself
    cheers
    richard
    shogun7's Avatar
    shogun7 Guest
    When I was a mechanic and I was troubleshooting an electrical problem I always fixed the problem with WD 40 and never had to replace any defective electric control. Boy thats good stuff LMAO
    Roger
    shogun7's Avatar
    shogun7 Guest
    Richard... A little dab il do ya!
    Roger
    Jun 2003
    Georgia
    72
    22
    Peter.... That is not a compressor you are showing! It is the new Copeland Piston Puzzle Kit Toy, part number #00 (Uh Oh)
    Aug 2002
    uk
    55
    14
    Exclamation Re: Broken compressor
    are you mad!!!!
    Aug 2002
    uk
    55
    14
    peter,did you buy new parts or stick them back together?
    May 2003
    Edmonton alberta Canada
    95
    22
    I have spent the better part of my life working on rinks should I say since 1963 so I have seen many broken compressors in nh3 and R22 ,.I always preferred to work on the NH3 but could do both. I saw the pictures and I do agree the compressor was flooding liguid and washed out the oil or diluted it so bad it no longer would lub the mains or throws anyway it is a problem with some systems. I have installed some suction accumulators which do help but you do have to have good oil return. what systems to you use flooded or txv chillers where you are . I do have to go now but am very interested in this subject so will talk later.
    Wes Maxfield
    Wes Maxfield
    May 2003
    95
    22
    Quote Originally Posted by shogun7
    Roger
    Their is not a service truck in Canada without WD40 it is the greatest stuff in the world it will fix anything but a hangover
    and it will even help that. Wes Maxfield
    Wes Maxfield
  1. can overfilling/overcharging damage a compressor?
    By fredjchavez in forum Trouble Shooting
    Last Post: 12-02-2009, 10:30 AM
  2. Compressor pumping efficiency
    By shogun7 in forum Fundamentals
    Last Post: 25-02-2004, 10:50 PM
  3. One Half of a Part Wound Compressor Motor is Burnt
    By aygul in forum Trouble Shooting
    Last Post: 25-08-2003, 11:11 AM
  4. Compressor failure...... cause
    By herefishy in forum Technical Speculations
    Last Post: 06-12-2002, 12:15 AM
  5. Starting a compressor, and receiver questions.
    Last Post: 24-08-2002, 12:37 PM
