Thread: Aspen Universal Con Pump
22-03-2004, 08:45 PM #1
Hi Guys ,
Fitted one of the above to-day,just a set of mains to it for power but how does it work ? does it sense a temp diff across the two sensor leads ? anybody explain to a thick spark????
Thanks again,
Frank McBride.
22-03-2004, 08:52 PM #2
Originally Posted by frankmcbride
22-03-2004, 09:03 PM #3
Hello Frank,
Aspen pumps are quite popular over hear. Just one piece of advice if you come accross these in the future. always check the pump head tube (White pipe goes around 180 degree's) These after time begin to go flat where the wheels go round them all the time and therefore looses some of it's pumping ability. New pump head tubes are available from all good stockists at about £5 each and are a piece of cake to fit.
Raymond
22-03-2004, 10:06 PM #4
Re: Aspen Universal Con Pump
Frank, we assume that you have read the instructions so don't call yourself a thick sparky
Also make sure that you mount the pump the correct way up otherwise the grease comes out of the bearings and the thing shuts down.Brian - Newton Abbot, Devon, UK
23-03-2004, 07:24 PM #5
Thanks for that guys.............. yes i`ve fitted the wee white tubes ,got them through Control Centre, visted site to-day and Daikin indoor unit & pump doing fine. I find every day is a school day learning all the time i`ve got my Corgi Card Industrial & commercial elements & now dabbling in A C & with the help i`m getting from you guys and reading all your postings i`m learning more.
Frank McBride.
liquid ammonia pump calvitation
By Kathleen in forum Trouble ShootingReplies: 23Last Post: 20-05-2011, 02:18 AM -
frostles heat pump
How to make ice with a heat pump
By Brian_UK in forum Chit Chat & Service StoriesReplies: 8Last Post: 23-03-2006, 09:09 PM -
New pump
By Peter_1 in forum Air ConditioningReplies: 1Last Post: 13-12-2003, 06:19 PM -
System Pump Down
By Brian_UK in forum Technical SpeculationsReplies: 16Last Post: 25-10-2001, 10:39 PM
