    joaquim pereira's Avatar
    joaquim pereira Guest
    Unhappy dx alp 100 mc quay
    hi
    i am having a problem with this dx system which is having a flood back ,after changing the EXV still the problem is same ,the AHU cap 37000 btu.even thou the ahu is running u can still open the motor panel door without any force,is the AHU under cap or their any other problem beside this
    Re: dx alp 100 mc quay
    Are there any duct dampers that have been closed ?
    Fire dampers ?
    If no suction pressure on fan then the discharge is blocked somewhere.
    Resolve airflow problem before touching the refrigeration side.
  1. Mc Quay AGR 124.2 chiller
    By borley in forum Industrial
    Last Post: 01-12-2007, 02:02 AM
  2. Mc Quay engineering manual no. 95-B
    By craigo in forum Refrigeration Books
    Last Post: 12-10-2007, 07:09 PM
