Thread: AHU 3 port valves
04-10-2008, 09:01 AM #1
AHU 3 port valves
I have seen Treated Fresh Air Air Handling Unit fitted with 3 way modulating valve.
Is it ok?
04-10-2008, 01:24 PM #2
Re: modulating valve with treated fresh air AHU
Of course it is.
04-10-2008, 09:47 PM #3
Do you mean 3way valves on the coils?
If so, it deends on what type of system you've got on it.
Variable flow or constant flow!
05-10-2008, 05:49 PM #4
Why is this post in 'Ye Old Wives Tales' ????
05-10-2008, 08:59 PM #5
Re: AHU 3 port valves
The valve is controlled by the leaving air temperature and it is keeping it constant by mixing the incoming water with the outgoing water
Stainless steel valves
By Tycho in forum NH3Replies: 5Last Post: 05-11-2008, 02:16 PM -
Understanding Balance port TX valves
By Mobbsy in forum Technical DiscussionsReplies: 12Last Post: 23-07-2008, 04:32 AM -
Hinari and how far to open valves
By stryker in forum Air ConditioningReplies: 6Last Post: 14-04-2008, 01:47 AM -
dan foss tx valves
By fuzzy in forum Trouble ShootingReplies: 7Last Post: 02-10-2007, 01:11 PM -
Balanced port TEVs
By Prof Sporlan in forum FundamentalsReplies: 22Last Post: 25-02-2002, 03:43 PM
