Thread: carrier split not heating
01-10-2008, 08:40 PM #1
hi,
i have a carrier split heat pump that will not turn compressor on for heat mode...i ran system in cool which is fine....it has an ir controller tried setpoint at 29 degrees with the sensor dipped in 5 degree water and still no sign of it working....ant ideas or better still any manuals..
rgrds phil
01-10-2008, 10:45 PM #2
Re: carrier split not heating
Can't help with problem, sorry but try here for manuals....
http://www.heronhill.co.uk/spare-parts/carrier/Brian - Newton Abbot, Devon, UK
Heating not working on split system what is the problem?
By airflo in forum Air ConditioningReplies: 10Last Post: 22-07-2008, 06:42 PM -
carrier split unit R22
By airconadam in forum Air ConditioningReplies: 24Last Post: 06-11-2007, 11:22 PM -
the carrier split draw amper more than notmal
By karimihassan in forum Air ConditioningReplies: 5Last Post: 19-08-2007, 12:20 AM
