23-09-2008, 10:32 PM #1
Aaparature for acumulation refrigerant
I am a new here
What kind of aparature I must to use to accumulate the refrigerant from the colding sistems. I please somebody to help me.Here in kosovo in my state nobody dont use aparature to accumulate the refrigerant it is to bad for atmosphere (ozon)
23-09-2008, 11:09 PM #2
Re: Aaparature for acumulation refrigerant
I think that you are looking for a recovery machine such as shown here..
http://www.ryanairconspares.com/refr...100-p-326.htmlBrian - Newton Abbot, Devon, UK
24-09-2008, 12:27 AM #3
Thanks for answer in my question But I didnt think in recovery machine I thought
in in machine who accumulate the refrigerant from air conditions colding sistem to any tank .In kosovo we open the colding sistems and we lose the refrigerant in atmosfera.It is not goot for ozon.So I need a machine who is in able to get refrigerant from air condition and to save in tank.if you can help me about this kind of machines I will be to much thanks to you.
24-09-2008, 08:23 AM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
24-09-2008, 11:36 AM #5
You need to use a recovery machine and separate refrigerant cylinders to accumulate the recovered refrigerant.
24-09-2008, 03:47 PM #6
Hi Brian
thank you wery much for answer .Maybe my english is a problem because I didnt understend what is recovery machine I am a new here .Now everithing is clear to me .I have made one aparature to akumulate the refrigerant .I done this from fridge compresor and it work quite good end I use again the accumulated refrigerant .But when I acumulate the lliquid
in the cilinder arrive very hight temperatures so sometime I fill afraid for any explosion .I thought to make one condensator in the enter of cilinder to low the paramiters of liquid refregerant so to do any solution.But I thought to ask for any aparatures with cilinders to accumulate minimum three kinds of refrigerant(three cilinders) .The recovery machines are exactly what I need .But what about cilinders where I can find the cilinders end when I accumulate the refrigerant in cilinder does recovery machine low the paramiters of refregerant to not heat the cilinders.For the end I must thanks you BRIAN for your exelent advices.I wish all the bes to you and to all members.
24-09-2008, 04:16 PM #7
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
You can find cylinders in specialized stores for refrigeration equipment. Here in Croatia that is Frigokor or MB-Frigo. I don't know for such a store in Kosovo.
Recovery machine has high pressure switch to prevent from overheating, but you need to weigh in recovered refrigerant to avoid charging it more than 80% of his maximum charge.
24-09-2008, 11:26 PM #8
Thanks Nike.
Superheat and Subcooling
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
MHI FDCA400HKXRE4 Tech Info Please
By L.JT in forum Trouble ShootingReplies: 5Last Post: 23-08-2008, 11:00 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM
