    xcd's Avatar
    xcd Guest
    Calculate press drop
    Anyone can help me how to calculate pressure drop of axcial fan after blowing through FCU ( FCU is 500mm (H) and 1200 (w) )
    Re: Calculate press drop
    No, impossible for us to perform that calculation with such limited information.
    Why not measure the pressure drop?
    Coil manufacturer should be able to provide air side pressure loss tables.
  1. Pressure drop air side coils
    By Friobernal in forum Technical Speculations
    Last Post: 17-09-2010, 04:19 PM
  2. A question about the pressure drop in coil .
    By jackcn in forum Fundamentals
    Last Post: 13-12-2008, 05:10 PM
  3. pressure drop of pump return line ammonia
    By Moeller in forum Fundamentals
    Last Post: 04-09-2007, 05:21 AM
  4. Optimal pressure drop in condensers and evaporators
    By MrReds in forum Refrigerants
    Last Post: 06-10-2006, 10:12 PM
  5. TEV capacity related to pressure drop
    By DaBit in forum CPU Overclockers
    Last Post: 06-12-2002, 05:11 PM
