Thread: R134a Replacement
02-08-2008, 06:34 PM #1
R134a Replacement
What is the best and optimal Refrigerant for replacing R134a?
02-08-2008, 07:21 PM #2
Re: R134a Replacement
why are you replacing it?
you could use r409a which is an R12 drop-in, it will run on snythetic and mineral oils
04-08-2008, 05:20 AM #3
What about R-407a?
can i replace r134a with r407a?
04-08-2008, 02:08 PM #4
Don't use R409 it contains R22 which is on its way out.
Why do you want to repace R134a?
04-08-2008, 02:12 PM #5
No reason to replace R134a. What for?
05-08-2008, 08:40 PM #6
Would go with r413a just incase you come across old r12 systems.
07-08-2008, 11:13 PM #7
Best match is R413A which can be used long term. is designed for mineral oil but works well with polyolesters etc and has fairly similar characteristics but with a generally lower charge weight.Your local isceon supplier can give you the full data the trade nane is isceom M049
Brit
08-08-2008, 02:02 AM #8
hi guy here in brazil im use r413a in replade r134 good luck
R507 in an R134a compressor: any danger?
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 21-12-2009, 12:44 AM -
R134a replacement help
By Bill in forum FundamentalsReplies: 8Last Post: 27-02-2006, 05:18 PM -
Pressure Transmitter R134a Setpoints
By cooltrain in forum Technical SpeculationsReplies: 0Last Post: 28-02-2005, 09:05 AM -
Is there anything about R134a that is better than R12?
By dude in forum RefrigerantsReplies: 5Last Post: 01-03-2004, 09:59 PM -
R507 in an R134a compressor: system design
By DaBit in forum Technical SpeculationsReplies: 17Last Post: 01-05-2003, 09:25 AM
