    ace face's Avatar
    ace face Guest
    samsung rs21dgrs fridge problem
    the evaporator fan in the fridge side has been getting noisy and since returning from holiday the led display was flashing and the fridge was warmer and ice is starting to form inside also how on earth do you get to all off this???????
    Jul 2007
    Australia
    1,845
    Re: samsung rs21dgrs fridge problem
    Same as all the others, evap fan iced up due to system not defrosting, or insulation getting water logged.
    Nearly every samsung mentioned in the forum has the same fault, so there's heaps of info if you search.
    Pull the inside evap cover off, if the coil is a block of ice, you have a defrost sensor, t/fuse or heater element problem
    Jul 2006
    norfolk
    737
    the fault for all these is defrost sensor failure need to replace it, can supply u one if needed
    ace face's Avatar
    ace face Guest
    Quote Originally Posted by tonto33 View Post
    yes would like you to supply one also can you supply t/fuse and heater element??
    Jul 2006
    norfolk
    737
    yes no problem pm me and will sort it
    Jul 2007
    Australia
    1,845
    He won't be able to PM with only 2 posts.
    Jul 2006
    norfolk
    737
    ok thanx for that have to email me then airkool@hotmail.co.uk
  1. coolinf fan problem samsung rs21 dgrs fridge freezer
    By bogtrotter in forum Trouble Shooting
    Last Post: 21-03-2008, 08:45 PM
  2. Samsung RS21 DCNS Fridge too warm
    By Divekate in forum Trouble Shooting
    Last Post: 26-02-2007, 05:12 PM
