Results 1 to 12 of 12
Thread: Air Conditioning Loads
02-06-2008, 04:30 PM #1
Does anyone know of a fairly simple calculator that can help you work out the cooling capacity required in a room.
For college I need to design a cooling system but our teacher left before she could teach us how, any ideas?
03-06-2008, 12:44 AM #2
Re: Air Conditioning Loads
Try Coolpack or even better use a text book and calculator.
Doing it the hard way teaches moreBrian - Newton Abbot, Devon, UK
04-06-2008, 06:23 PM #3
"dircalc" from Danfoss, its available at the danfoss site,and free
Ice
04-06-2008, 06:57 PM #4
A rough guide is as follow but various other factors need to be taken into account like windows , heat load people , south facing etc etc.
Length in metres x height x width x 40 watts = total kw required to cool down area. Example 5m x 5m x 2m x 40w = 2000w /2kw cooling capacity . but the above factors will need to be considered.Transvestites are men who like to eat, drink, and be Mary.
25-07-2008, 12:36 AM #5
25-07-2008, 12:45 AM #6
25-07-2008, 02:13 AM #7
go to the college library
Take the V out of HVAC and you are left with a HAC job
28-07-2008, 05:22 PM #8
so, what is the simple formula in determining the cooling load of a certain area..? pls help..tnx
28-07-2008, 10:59 PM #9
28-07-2008, 11:09 PM #10
this from an old post of mine is a rough guide
http://www.refrigeration-engineer.co...ead.php?t=8940Paul
"KEEP IT COOL"
28-07-2008, 11:48 PM #11
Are you really too lazy to do the ground work.If we all had the help that was available on this site a good few years ago then you would not need to study at all. you could pass the exams no probs. Get a grip and do your studies like most of had to do and forget about what you are going to do at the weekend because if you are going to be good you won't be out at weekends anyway.
29-07-2008, 07:02 AM #12
give me yr email, i will send the daikin load soft ware.
Air Conditioning Courses
By stesmith1981 in forum IndustrialReplies: 8Last Post: 09-03-2010, 06:33 PM -
Refrigeration with Air Conditioning Compressors
By Samarjit Sen in forum Air ConditioningReplies: 6Last Post: 02-02-2009, 11:02 AM -
Unique cooling system Port-A-Cool replaces air conditioning
By LC-Europe in forum New TechnologiesReplies: 20Last Post: 30-01-2008, 08:29 AM -
Certificate in Mobile Air Conditioning Systems
By Tony in forum TrainingReplies: 2Last Post: 01-07-2007, 04:30 PM
