Results 1 to 33 of 33
Thread: what is this?
    Sep 2003
    ISRAEL
    72
    4,248
    Question what is this?
    hi everybody,
    attached , is a picture of milk tank unit.
    waht you see is some kind of suction line acumulator, liquid line is connected at the bottom with unfamiliar expention device. adjusting is inside.
    runs on R-12. now works fine.
    evaporator is a flooded.
    anyone ever came accross such machine?
    anyone knows whats inside that 4" pipe and how exactly does it work?
    chemi
    Jun 2002
    628
    chemi-cool
    All the dx milk cooling tanks (ive seen) have had the suction line accumulator at the condensing unit end .With a high wattage heater tape wrapped round to aid the accumulators function ie fabdec,mueller tanks.(depends on field conditions)
    Have you pumped the c/u unit down and looked whether theres any sort of expansion,or metering device,at the inlet of the vessel.(If its dx.)
    It looks like the vessel pictured is some sort of liquid sub-cooler.
    regards mark
    Sep 2003
    ISRAEL
    72
    4,248
    hi mark,
    there is such a device at the bottom, to adjust it you have to pumpdown and open the nut .
    I wil get another picture of ti tomorow.
    chemi
    Jun 2002
    628
    hello chemi-cool
    If its dx and the (evaparator is flooded for maximum heat transfer),then a fixed metering device or expansion nozzle is sometimes fitted.
    Usually if installed and sized appropriately ,and unless showing signs of a serious restriction.The metering device etc usually cannot be adjusted( physically) only cleaned and/ or replaced.
    As it has no form of adjustment only merely a restrictor .
    hope this helps
    kind regards
    mark
    Apr 2002
    Pennsylvania, USA
    55
    78
    I take care of a few bulk tanks.
    All but one (which has an AXV) are fitted with low side floats.
    Sep 2003
    ISRAEL
    72
    4,248
    hi condenceddave,
    can you post a picture? or the literature of these equipment?
    thanks
    chemi
    Apr 2002
    Pennsylvania, USA
    55
    78
    I can get a pic next time I'm on one. Never really thought to start photographing this old equipment. (Off-topic, but the one dairy farm has a really neat old "Behlen" grain drier that is propane fired. The ignition module is a point/condenser off of a Ford Model T!) Old farm equipment is really very interesting, as are old farmers stories about how they came up with solutions mechanical problems with next to no money.
    There is zero literature left for any of these. The newest one is over 30 years old.
    I've converted one to 134a, BTW, with great results.
    Sep 2003
    ISRAEL
    72
    4,248
    hi condenceddave,
    thanks, I'll wait to see it.
    over here, no more of these small farms, they are all new and big now and everything is modernized. how baoring.
    chemi
    Apr 2002
    Pennsylvania, USA
    55
    78
    I blew up your photo to 1200x900. That looks like a low side float, but the design of it is confusing.
    I think the angle is throwing me off.
    Is that a sightglass at the bottom?
    Sep 2003
    ISRAEL
    72
    4,248
    will get this afternoon another picture of the bottom.
    it could be a low side flaot. that was the first idea when I first saw it.
    chemi
    Apr 2002
    Pennsylvania, USA
    55
    78
    The ones I work on are older than dirt, so the design is obviously different. I've never seen a "new" one. It very well could be that. It's the best way I know of to flood an evap.
    Sep 2003
    ISRAEL
    72
    4,248
    hi condenceddave,
    attached is a picture of the metering or expention device.
    it says on it STREAMLINE, could not see any numbers but if you say that should be I'll check again.
    mark, where is ANDY?
    chemi
    Sep 2003
    ISRAEL
    72
    4,248
    Talking
    woooooooooooops.......
    forgot the attachment. here it is.
    chemi
    Apr 2001
    79
    5,071
    35
    A float tank would have connections to the top and bottom of the evaporator shell in order to maintain a representative level, and the sight glass would be near the top, not the bottom.
    It doesn't make sense as a subcooler either, because the two side pipes would be the liquid lines going into the milk tank, and they are much larger than the liquid line entering the vessel.
    I vote for accumulator, with the two side pipes being the suction lines from the tank, although the bottom feed would cool rather than warm the suction gas. Maybe a de-superheater?
    I'm thinking the expansion device feeds the bulk of the refrigerant straight back to the evaporator tubes in the milk tank.
    But then, I'm just taking a wild guess.
    Jun 2001
    N.Ireland
    1,630
    what makes you think I know what it is
    Might be a thing called a liquid injector, works by venturi effect. The high pressure liquid passing thru a metering device causes a venturi effect, creating a lower pressure area in the flood bottle, allowing a bottom fed evaporator to work as in a liquid overfeed system. Commonly used in Mojo systems, for cooling syrups in the drinks industry.
    That's my best guess
    feel free to comment as it is only a guess
    Regards. Andy
    Oct 2003
    5,630
    What are Mojo systems Andy?
    Anyway, it stays a unique piece of antique which Chemi has to treat as his do with his wife .....I think......., he fixed her lights on a holiday LOL
    Jun 2001
    N.Ireland
    1,630
    Hi Marc
    I would call this a semi-critical charge system. Charge is critical, but a slight under/over charge can be compensated for by adjusting the regulator valve.
    The injector works like this. High pressure liquid drops in pressure thru the restrictor valve and usualy a venturi oriface. This liquid forcing thru the oriface plate causes a slight vaccumn. The slight vaccumn sucks the liquid from the flood bottle into the passing liquid stream, stopping the liquid from buliding up in the flood bottle and ending up in the compressor. Basically the system is liqui overfeed with more liquid circulated than can be boiled of in the evaporator. I am assuming that the dry suction dips down in a U shape, with a small hole in the bottem of the U allowing the oil rich refrigerant at the liquid level to pass into the compressor suction, effectivly rectifying the oil from the flood bottle. The working level is seen in the sight glass in the bottom of the flood bottle.
    Regards. Andy
    Jun 2001
    N.Ireland
    1,630
    Hi Peter
    a mojo is a mojorena unit (probably not spelt right) an american trade name of the company that makes these syrup cooling drums, principaly used in the soft drinks industry.
    Regards. Andy.
    Sep 2003
    ISRAEL
    72
    4,248
    Thumbs up
    hi andy,
    it was markfiddy's: "I expect andy will tell you the answer ".
    I like what you have written. it make sense to me.
    any way I have started a search with a help of a friend arround small dairy farms in the country to find on more unit which I can cut and share with all of you the results.
    I will make another investigation of that metering device at the bottom, it requiers some acrobatic but I think i will manage.
    I am looking for a manufacturer name and model.
    chemi
    Sep 2003
    ISRAEL
    72
    4,248
    hi marc,
    the condensing unit equiped with an oil sapetator and I didnt see any sign of low level oil in the compressor so as a problem its ruled out.
    I have checked the metering, expention device and on one side it written STREAMLINE and on the other side 48. maybe manufacturing year?
    Abit of patient, and I will get another unit and cut it open.
    chemi
    rbartlett's Avatar
    rbartlett Guest
    isn't streamline -mueller?
    http://www.muellerindustries.com/
    cheers
    richard
    Sep 2003
    ISRAEL
    72
    4,248
    hi richard,
    you are right but mueller went through a lot of chages since, so I'm sure they dont make those things any more.
    I have found a second hand milk tanks seller in holland and I will get in touch with them after the weekend, maybe they will be helpfull.
    by the way richard, you have asked a few months ago on another thread "what KSA stands for" well its KINGDOM SAUDI ARABIA.
    chemi
  23. #23
    Jun 2002
    628
    Post what is this?
    hello chemi - cool
    How are you?Im still thinking The vessel is like a slop pot and the metering device is just like a restrictor. thats just my opinion.
    I was just having a bit of fun when saying "i expect andy will tell you the answer" .
    have fun with it chemi-cool i know you will come to some logical answer .
    regards mark
  24. #24
    Jun 2002
    628
    what is this?
    chemi-cool
    Is there a liquid reciever on the condensing unit?.This might help establish what sort of metering device is fitted.
  25. #25
    Sep 2003
    ISRAEL
    72
    4,248
    hi mark,
    there is no liquid reciver on the condensing unit.
    the condenser coil is designed to hold the liquid.
    even when I close the hand valve before the drier and preform manual pump down, its big enough to hold all the liquid.
    chemi
  26. #26
    Sep 2003
    ISRAEL
    72
    4,248
    richard,
    having fun and laughing is an important part of our life!!
    chemi
  27. #27
    Jun 2002
    628
    Post what is this?
    hi chemi-cool
    Ive just been looking at the jpg (again) ,I believe its a suction line accumulator with a built in heat exchanger with the metering device at the inlet.
    Did you obtain any more info chemi?.
    regards mark
  28. #28
    Jun 2002
    628
    what is this?
    Originally posted by Marc O'Brien
    48 cubic inch filter drier shell?
    A 48 cubic inch filter drier modified?
    your a funny guy marc
  29. #29
    Jun 2002
    628
    Post what is this?
    no comment marc
  30. #30
    Sep 2003
    ISRAEL
    72
    4,248
    Thumbs up
    well mark,
    I have found on a dairy farm in the north of the country another unit and the owner is kipping it for me.
    mean while I saw in a book called: COLD AND CHILLED STORAGE TECHNOLOGY written by a bunch of talanted english guys,
    a description of a system called: gravity recirculation system. I belive that I am home,. meaning, this is it.
    I will scan the pages one of these days and post them.
    I'm begining to like Marc and his ideas. his way is a good way to come to the point of the matter, even if it goes in funny ways sometimes.
    chemi
  31. #31
    Jun 2002
    628
    what is this?
    chemi
    Do you mean circulated refrigerant / overfed .This configuration of pipework does not match that description.Or am i wrong?
    regards mark
  32. #32
    Sep 2003
    ISRAEL
    72
    4,248
    I mean, GRAVITY RECIRCULATION SYSTEM.
    pipes configuration is the same. and I'm almost completly sure.
    I will get it eventually.
    chemi
  33. #33
    Jun 2002
    628
    what is this?
    ok chemi-cool.
    mark
