Thread: what instrument???
22-06-2008, 10:48 PM #1
what instrument???
What instrument would u use to measure after installing a new crankshaft to a compressor???
22-06-2008, 11:19 PM #2
Re: what instrument???
What is it that you are trying to measure ?
22-06-2008, 11:25 PM #3
Hi brian..
Its actually a question from college work..its says..assuming the compressor needs to be rebuilt-after installing a new crankshaft what measurement would you take before proceeding any further...it then asks what instrument would u use to measure this???
Any guesses???
22-06-2008, 11:29 PM #4
am jealous on 2 counts.
1st- there were no college courses to do when i served my time
2nd- if there had been there wouldnt have been the internet to do cheatin on! :-D
dont you take notes or get some instruction before they ask you questions like this?
22-06-2008, 11:39 PM #5
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
22-06-2008, 11:53 PM #6
Sorry, the question is still a little open-ended.
Is the compressor fully rebuilt and connected, regassed etc or are we still at the stage of fitting the crankshaft ?
The amperage check is good as above.
If still being assembled then a dial test indicator to check the shaft is square, micrometers, feeler gauges, all sorts of things....Brian - Newton Abbot, Devon, UK
22-06-2008, 11:55 PM #7
How about end float?
23-06-2008, 01:23 AM #8
It all depends on what sort of compressor it is. the main checks I would do are for end float (dial gauge), shaft allignment (dial gauge), journal size ( micrometer or vernier). But looking at the question again I would go for the end float measurement with a dial gauge or DTI if that is what you know it as.
Ian
digital manifold
By wilks in forum Tools and CalculatorsReplies: 20Last Post: 16-09-2010, 09:11 AM
