Thread: traulsen freezer
08-06-2008, 03:42 AM #1
traulsen freezer
Hi,well its been about a year when I last posted on here.My family opened a resturaunt about a year ago.everythings going pretty good except for our three door traulsen freezer defrost timer is acting up again.This is the new one that I installed .I guess the points are getting pitted and not making good contact.I filed them and got it going again .I was just wondering can this be converted to an electronic timer.thanks for the help.
08-06-2008, 10:21 AM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: traulsen freezer
Of course it can. There are many electronic thermostats wit defrost timers built in them.
For example:
http://www.invensyscontrolseurope.co...ers/ICCont.htm
Or only defrost timer:
http://www.invensyscontrolseurope.co...imers/EWTS.htm
Question is what is readily available in your country.
08-06-2008, 11:29 PM #3
It might also be worth while checking the electrical loading on the switchgear.
Perhaps introduce an extra relay or contactor to handle the load with the timer only switched the relays/contactors.Brian - Newton Abbot, Devon, UK
09-06-2008, 01:43 PM #4
From memory I think the timeclock fitted to traulsen freezers is one of the paragon metal case timeclocks. Probably easier to stick with the same mechanical timer as fitting an electronic controller would not be a pretty site. Be best as Brian stated you could fit an external contactor for compressor / defrost ? load.
Transvestites are men who like to eat, drink, and be Mary.
Freezer compressor running 20 Hours/day
By rickcw in forum DomesticReplies: 12Last Post: 08-03-2008, 11:50 PM -
Need help quick with walk-in freezer issues!
By hysiderafter in forum CommercialReplies: 5Last Post: 12-12-2007, 12:57 AM -
Trolley freezer & blast freezer
By smpsmp45 in forum NH3Replies: 0Last Post: 25-08-2007, 07:29 AM -
Project needs a freezer box.
By NC-Joey in forum FundamentalsReplies: 14Last Post: 16-08-2007, 01:27 PM -
Freezer efficiency questions
By M_Q in forum FundamentalsReplies: 8Last Post: 20-03-2007, 04:38 PM
