Thread: Eutectic Auto fridge
31-05-2008, 01:54 AM #1
Gday, I;ve got a question about a 73lt auto fridge. The instructions state that the fridge will cut out operation when the voltage drops below 12volts. Indicating by a 4 second flash of the red light behind the thermstate controler. My fridge is voltage faulting when my battery voltage drops below 13volts which is when I turn off the 240v supply to the charging circuit of the camper trailer. Is there an adjustable resister in the fridge to adjust?? Any help will be appreciated...Thanks
31-05-2008, 04:05 PM #2
Re: Eutectic Auto fridge
Hello Rob
Most fridges suffer from the electical cable being too small or connectors heating up & not doing the job. You didn't say whether you checked the voltage actually at the fridge controller terminals.
The std voltage cut outs for the Danfoss 12v compressor fridge is 10.4 v & can be altered with a different resistor at R2 in the control circuit.
I don't think I would go any lower than this as you will murder the battery & it will cause long term damage.
Hope this helps - Leigh
01-06-2008, 12:34 AM #3
A make and model might help us to help you.
BOSCH Fridge/Freezer - fridge wont cool....freezer fine
By andy_lanc in forum DomesticReplies: 6Last Post: 25-10-2010, 01:25 PM -
Fridge part of frost-free fridge-freezer icing up?
By rumpelstiltskin in forum DomesticReplies: 18Last Post: 01-06-2010, 09:56 AM -
Should dial change fridge temperature??
By Trisha in forum Trouble ShootingReplies: 6Last Post: 12-02-2007, 08:00 PM -
help- my bar fridge is wacko?!
By ben in forum Trouble ShootingReplies: 3Last Post: 25-01-2002, 12:06 AM -
is my fridge working properly?
By vincec in forum Trouble ShootingReplies: 1Last Post: 15-01-2002, 09:55 PM
