    Jun 2001
    N.Ireland
    1,630
    Arrow Modern NH3 Refrigeration Plants
    I have attached a photo of a NH3 refrigeration plant, this plant has two 150hp compressors fitted to a common oil separator and Low Pressure Receiver. This is a 5 year old plant, with the picture taken last week when I was on site.
    The photo is a side veiw with the black insulated LPR on the left and the screw pack on the right.
    All comments apreciated good or bad, I hope the photo comes out alright give us a shout if it doesn't.
    Regards. Andy.
    Aug 2001
    NE Lincolnshire, UK
    145
    Errrr.....
    Looks..."compact" doesn't it. Which generally means you cannot get to anything important without hanging by your toes off some steel beam.
    Perhaps we ought to have new thread here...do the people who design plants and machinery ever get to think about servicing them..
    Integrated hydraulics - there's a good phrase - means you have to be a triple jointed midget to get at anything - perhaps these designers have something in common with the makers of these packaged units that equipment makers are trying to sell us.
    I realise now why I have never seen an overweight fridge engineer - they would never stand a chance getting to the gear to service it
    Steve
    Jun 2001
    N.Ireland
    1,630
    Talking Compact Plant
    Hi, Steve
    I suppose from that side it does look compact, that's the side that I normally wouldn't be working at much. I have attached another photo of the unit from the frount showing the two Howdens. The whole thing is 20' long, not so compact really, not a bad unit to work on, the big bits are very easy to get at.
    But you are right, some units are real pigs to work at, that ice rink pack was a bit tight for working at, especially if you had to take the heads off No3 compressor.
    I hope the picture below looks a little better to you.
    Regards. Andy.
    May 2003
    Canada
    Hi Andy, doesnt look to bad to work on. What kind of screws are those? I do alot of work on the Frick screws and am curious to find out about some of the other brands out there.
    Jun 2001
    N.Ireland
    1,630
    Hi Industrial Tech,
    welcome to the Industrial Section
    Theses are Howden screws, built in Glasgow. 165-145 rotor profiles and the smallest product we use from Howden.
    Quite a nice screw to work on and simple to work on.
    Everlasting, given a little care and maintenance.
    On this side of the pond, Fricks were sold by Gram under licience
    I have worked on a few, with little bother, except the dinky little LVDT used to give the slide position to PLC controller.
    Regards. Andy
    Dec 2001
    Cleveland
    Alright Andy
    Have you worked on any Stal screws I have worked on the vertical mini screw using thermo syphon oil coolers seemed a decent machine
    regards Dave
    Jun 2001
    N.Ireland
    1,630
    Hi, Dave,
    I have not worked on any Stall screws recently. I am afraid to say the Stal mini-screw has a bad name in Ireland, or at least in the circles I move in. Although this is probably down to one contractor who mis-applied them on most of his industrial plants. These plants were nearly alway DX R22, with a hot gas defrost that dumped liquid into a suction accumulator, which had no boil off coil, leading to flood back.
    Worked on a few Stal Recips, now those are a great machine
    Are they still made. I doubt it as they were far to good and nearly everlasting, not what manufacturers want today
    Marc
    As I recall, the twin screw is still made under licence from the original patent and profile developed in Sweden
    SRC or something similar profile name.
    Regards. Andy
    Jun 2001
    N.Ireland
    1,630
    Hi Marc,
    roughly translated as Swedish Rotor Machine
    Regards. Andy
    Jun 2003
    Georgia
    72
    22
    The last Stahls I voluntarily worked on had just catastrophically failed.... They had shaft-driven oil pumps. As those shaft drive bearings failed, they fell out of the race, and straight into the suction of the screw.... Screaming one minute, and a sound like a buzzsaw... then silence. Those were probably 1970s models. Since Stahl is now associated with one those larger manufacturers...
    ask's Avatar
    ask Guest
    Re: Modern NH3 Refrigeration Plants
    hey,
    I am a finaly year chemical engineering student studying in the UK. I have my final design project which is due in two weeks. I am a bit stuck with this as I haven't got much knowledge on this subject. My project is to design a chiller with NH3 as the refrigerant. this chiller is used to cool a water stream that comes out of a condenser at 20 C down to 3C. I specified the temperatures of the NH3 stream to be -45 C to 15 C and calculated the flow rate. Anyways I just wanted to get some basic idea about the main components of such a system and thing that you think might be useful for my design. Gosh you would be a life saviour if you could help out.. thank you...hope to hear from you soon
    Croatia
    68
    2,261
    Hi, ask
    Quote Originally Posted by ask View Post
    hey,
    .... so you have to cool water having freezing point at 0*C
    ... why you decide to use ammonia with temperature of -45*C
    .... can you make a sketch of your system showing where you think to have ammonia with -45*C to 15*C
    ... try to think about chiller with evaporating temperature of ammonia at 0*C
    BTW you should open a new thread with your question and not to use this one 5 years old
    Best regards, Josip
  1. advanced refrigeration technology
    Last Post: 16-02-2011, 05:22 PM
