    dave_k's Avatar
    dave_k Guest
    newbie earth bonding
    Hi all
    this is my first post so quite new here and to the refrigeration trade. I an working as aengineers mate on refrigeration installs. I have just passed my 17th edition but have yet to gain a lot of experian within the trade. ok my question?
    I recently assisted installing a large walk in freezer to which i did the wiring with some guidance from the engineers. Now on the evapourater drain is a heater coil which wraps around the copper pipe which is connecteds to the evap drain by a plastic fitting then the pipe runs outside to the drain. In my opinion this drain shoud be bonded as the only earth conetion under fault conditions would be human contact.
    cheers
    Dave
    Jan 2008
    Kent UK
    49
    514
    Re: newbie earth bonding
    Hi Dave
    Yes just earth the drain pipe to the main earth in the electrical panel and all should be ok.This is normal practice.
    Oh and welcome to RE
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Feb 2008
    Saudi Arabia
    52
    it is so nice Good luck
    70
    4,700
    47
    Quote Originally Posted by dave_k View Post
    Hi all
    cheers
    Dave
    Dave.
    I have just read your post.
    What form of heater are you useing??
    Because the normal form of heater tape. Is Self Regulating Double Insulated.
    It's a while since I last read up on this But surely you don't need Earth Bonding on a Double Insulated heater tape?
    Or has the regs changed again???
    Cheers Grizzly.
    Jul 2007
    44
    98
    Shouldnt the actual metal frame around the evap be bonded allready ?
    Jul 2007
    44
    98
    Red face Re: newbie earth bonding
    sorry!! assuming the thred is metal and not plastic!! that the drain connects to !
    Oct 2006
    1,843
    Copper drains need to be earth bonded. They are insulated from the evap by the plastic conection. If the heater tape was ever to get damaged and short out to the drain it would be lethal to anyone who touched it. The drain pipe needs to be earthed.
    taz.
    Jul 2007
    44
    98
    Quote Originally Posted by taz24 View Post
    taz.
    arh taz , sorry i forgot about that , just in the same way when bonding sinks and taps all must be done individually ( cold water , hot water and sink ) because of the rubber wahers and and seals ! doh !
    Oct 2006
    1,843
    Quote Originally Posted by wilks View Post
    Don't worry about it.
    When you've set fire to the drain like i did once because you wrapped it to tight with the wrong heater you learn things like this
    Cheers taz.
    Jul 2007
    44
    98
    Cheers taz.
    oops sounds scary !
    Oct 2006
    1,843
    oops sounds scary !
    I'd finished and was ten mins from store when phone rang and I was informed that the coldroom was smelling of burning.
    I turned round and got back to see the heater tape all chared, burnt and melted. Fourtunately the fuse blew when it shorted out and because it was a freezer it was too cold to cause a spread of thre fire.
    A bit embarassing but I managed to sort it out without too much micky taking from the other lads
    Cheers taz.
  1. Questions about NH3 from a wantabe newbie
    By Minuteman in forum NH3
    Last Post: 10-04-2007, 12:46 PM
  2. Earth faults
    By reggie in forum Technical Speculations
    Last Post: 28-01-2006, 06:22 PM
  3. Earth tapped transformers
    By phil68 in forum Fundamentals
    Last Post: 04-01-2006, 09:32 PM
  4. Intermolecular bonding
    By shogun7 in forum Technical Speculations
    Last Post: 19-03-2004, 11:31 PM
